Imalent
Results 1 to 7 of 7
Thread: Piston drive style
    Default Piston drive style
    Hi all,
    I'm after a piston drive flashlight. Currently have my eyes on the OG of the PD design: McGizmos. However, they are rare and obviously expensive...
    Having done some forum research, there are other options like the Nitecore and Arc6 but generally all PD designs seem to have been discontinued. Are there any PD style flashlights manufactured for sale in 2019? Those that have owned the McGizmos, any comparisons to the cheaper Nitecore or other PD lights?
    Any recommendations similar to the OG Ti-PD?
    I'm not after big lumens as I already have other lights that serve that purpose. I want to own a PD style light with emphasis on build quality and reliability.
    Moderator
    archimedes's Avatar
    Nov 2010
    CONUS, top left
    Default Re: Piston drive style
    All switch designs have strengths and weaknesses.
    It might help us advise you better, to know what it is about this design that you find appealing.
    ... is the archimedes peak
    I guess the idea of the piston drive switch seems very unique. Having not had a light with such a switch and reading the rave reviews about the McGizmo pd, I would love to own one. But I guess with the rarity if them; I'm wonder how the other brands might compare?
    Moderator
    archimedes's Avatar
    Nov 2010
    CONUS, top left
    Ok, I'll try my best to answer your questions below ....
    Quote Originally Posted by monty94 View Post
    .... I'm after a piston drive flashlight. Currently have my eyes on the OG of the PD design: McGizmos. However, they are rare and obviously expensive...
    The McGizmo PD series were generally produced and released in limited numbers, at the time. I wouldn't consider them "rare" as such, but were never really widely available in the same way that the current Haiku (say) can simply be ordered direct at your convenience.
    They have maintained their value well, especially in light of what are now the older emitters they used, but present secondary market pricing is not markedly different compared to back when their small runs were being sold in "waves"
    For a variety of reasons, a true piston drive is not the switch of choice for flashlights at this time.
    I really am not sure what you are asking about the comparison between McGizmo and Nitecore, but I would say the piston-drive lights of these two makers are about as different as possible from each other, in all but a narrowly-defined technical sense concerning a single part.
    Materials, UI, aesthetics, construction, etc, etc, in most every other relevant matter, they differ significantly.
    Although neither are common any longer, neither are particularly difficult to try and and find, if you are interested to do so.
    The variation(s) which ARE pretty rare / expensive / difficult to find, for completeness, are the @KuKu427 custom titanium runs.
    The McGizmo are the most robust of the piston-drive torches, but be aware that the PD design requires more maintenance than most other types of switches.
    A rough order of switch durability and reliability, from highest on down, would be ...
    • twist ( "battery crusher" type )
    • electronic "e-switch"
    • piston drive
    • mechanical "clicky"
    However, in most cases, I would prefer a clicky over a piston-drive for two reasons - ease of (inexpensive) replacement, and less maintenance.
    I am guessing that (as an alternative to the PD) , you may like a flashlight with an e-switch and a ramping UI, such as one of the many Emisar torches.
    Hope that all was helpful
    Although everyone compares the McGizmo PD to the Nitecore, they are extremely different. The Nitecore is basically an E-Switch driver, using the piston to push the button. The McGizmo uses the piston to closed contacts. If anything, the Peak tail switch is more similar to the McGizmo, if you view the batter in the Peak acting as the piston.
    Slightly related are various tail e switch lights, such as the Folomov EDC C1, FW3A, Acebeam TK16, HDS. . .
    peter yetman's Avatar
    Mar 2014
    North Norfolk UK
    I had nothing but trouble with the Nitecore PD, I think it was a lubrication thing.
    It took a lot of maintenance and was not very reliable.
    I ended up blowing up the driver, but that's another story.
    P
    Peter's shopping list:- HDS / Oveready 170N Exec/LE and an Oveready V4 Nichia Drop In. Otherwise I'm content. Want want want, that's me.
    Thanks, given me a few other brands and designs to look into. At this point I'm leaning towards a McGizmo because it also satisfies my cravings for a premium light.
