Dave D
Some of you may have noticed that my interest in flashlights is in duty lights.
I was an LEO for thirty years and therefore have some experience of using flashlight for this purpose.
The current market leader in the USA is probably the Streamlight Stinger.
Surefire released the R1 Lawman, with 700 lumens, which was then upgraded to 1000 before finally adding the IntelliBeam technology in the final version.
As nice as the Lawman was it was in the region of three time the price of a Stinger but didn't do anything better!!
I recently bought an old Surefire 8NX Commander and upgraded it with a Lumens Factory LED drop-in.
I have to say that the 8NX is a nice light when it's converted to LED.
I'm all for 'Keep It Simple Stupid' in Duty Lights and I like the lack of any mechanical switches, nothing to go wrong, the momentary tailcap that simply pushes the battery to make full contact with the springs on the underside of the drop-in. The head rotates for constant on, it is easily turned single handed by rotating the head with your thumb. This is a great feature because you don't have to locate a head switch in the dark before you can turn it on.
The Nitrolon body is comfy to handle in cold conditions and is large enough to accommodate a 21700 battery.
For me 800 lumens with a good mix off flood and spill is the sweet spot for Duty lights, it's not too bright to use in doors and it's not throwing too far that your eyes can't determine what it is that your illuminating.
I'm not a fan of strobe modes, they are simply a distraction technique, and I'm not aware of how many Departments actually train with strobes, especially with Taser now being more readily available.
This got me thinking that if Surefire were to release an LED 8NX, with two models (800/15 lumens) that always comes on in high and runs for up to 3 hours off a 217000 5000mAh battery then this would be an ideal Duty Light.
SF would need to produce a suitable battery cradle and even if they had to produce an aluminium head to assist with heat dispersal then this would be a low cost development process for them.
I'm sure that Surefire could produce these for less than the price of a Stinger, it would weight about 2/3 of a Stinger (8 1/4 oz), which in these days with the amount of equipment carried on duty belts is a big plus.
I've sent my suggestion to SF but to date I've had no response.
