HDS Clicky Executive UI
Nichia!
Banned
Hi my friends
I have little problem with my Executive Clicky.
I don't know how to program it! I have read the manual but I don't understand it! It's very hard to understand!
Now my light is doing this :-
From off one click goes to Turbo .
While on turbo double click goes to low (2-3 Lumens)
When I turn it off the flashlight now has dim flash every 3-4 seconds
I don't want the locator flash.
I want turbo maximum and low ( or little bit brighter than low)
What I want is
Just 2 mods turbo and low(10 Lumens if possible)
Tell me how to do it? I don't understand the instructions manual you tell me how please.
Thank you
Nichia!
Banned
I don't know about his YouTube channel and I don't know it.
Can you guys please tell me how to program it in simple words?
Nichia!
Banned
I can't understand how it works and how to program it. I spent 2 hours now trying to figure out how to do it right but I don't understand the instructions not even a little bit!
I just want to remove the dim flash when flashlight turned off it's just keep flashing
I want to have 2 mods only
Turbo (maximum) and low mod (10 Lumens if possible)
the0dore3524
California (Bay Area)
Just click four times from off and it'll disable the locator flash.
nbp
Wisconsin
Also, you will always have four modes, however you could set two of them to one output level and two of them to a second output level. You can't however make it just a "two mode" light.
trailhunter
Do you know what version firmware you running?
Sent from my SM-G970U using Tapatalk
Nichia!
Banned
When the light is off I press it 4 times quickly and it's doesn't turn off the locator. I did this many times and still the same thing
Nichia!
Banned
I tried to do the factory reset many times but it doesn't work. I don't know what firmware it's using but I have
The xpg (first Gen) high CRI 3700k
tyu
Albuquerque, NM
I think It would help if you could describe exactly what you are doing step-by-step, and exactly what you mean by "it doesn't work." Otherwise, I don't see how we can help you.
