Sky Lumen
Results 1 to 20 of 20
Thread: Locator Flash Speed/Brightness
    Jun 2014
    Albuquerque, NM
    Default Locator Flash Speed/Brightness
    What determines the speed of the locator flash? I would assume the clock signals would be relatively similar, resulting in flashes of similar speed, but I’ve noticed some of my lights flashing considerably faster than others.
    At what brightness level does the flash happen?
    Default Re: Locator Flash Speed/Brightness
    Quote Originally Posted by tyu View Post
    I believe it has to do with the blood pressure of the elf in the light... or heart rate.
    I'll try to remember to ask Henry on Monday... until then elf heart rate and blood pressure.
    I'm sure I'm right.
    Thor's Hammer Custom Leather
    HDS Systems Henry's Mini-Me
    I play with dead things
    Modernflame's Avatar
    Jan 2017
    Dirty Dirty South
    In my experience, it has more to do with the metric rate of beer consumption than anything. Pretty sure I can find a supporting link somewhere...
    “May it be a light to you in dark places, when all other lights go out.”
    J.R.R. Tolkien, The Fellowship of the Ring
    Jun 2014
    Albuquerque, NM
    I've been wanting to do this for a while: (edit: When putting everything back I realized I left 2 out. Oops.)
    Video in the light:
    Video in the dark:
    Still image:
    Flashaholic* INFRNL's Avatar
    Feb 2012
    Bottom Of Pikes Peak
    that's pretty cool. you need more lights; then you can makes some kind of disco ball party thing.
    Flashaholic* Slumber Pass's Avatar
    Sep 2011
    The Alamo City
    Very cool! Are the taller ones 18650's and the short ones are CR123?
    Oct 2009
    In the middle of Europe
    Absence from blod pressure, heart rate, beer and other interesting things. Here I have a description:
    I assume the Microcontroller that is used in the HDS (aka Elf) uses the internal oscillator. This occillator has a specific deviation. That means one Controller uses an interal Clock of let say 3.005MHz, and other one uses 2.992MHz due to the deviation that Comes from the manufacturing process. Depending on how the locator Flash is being created in the Software Code it is been done by Interrupt / usage of internal timers or delay loops. But anyway how the locator Flash is done, the timer uses the clock and therefore the Deviation will go into a Deviation of the locatior Flash directly. It the locator Flash is creted with delay loops than the fact is ech command Needs a specific number of Clock cycles to be executed. If a Microcontroller has a Clock that is a Little bit higher, the delay is Shorter and vice versa.
    But I agree Hogos Explanation is easier to understand…
    Still looking for Surefire G2 in Orange.
    If you have one you don't like please PM me.
    Jun 2014
    Albuquerque, NM
    Quote Originally Posted by Slumber Pass View Post
    Yes.
    Feb 2012
    Quote Originally Posted by WarriorOfLight View Post
    thanks, a bit ove rmy head but the last part makes perfect sense to me.
    i played around with 3 of mine today and they played music together. I neve payed any attention to this; although i have never turned on the locator flash on more than one light either until TYU posted this thread
    I have done this before with two of my lights, one is a High Noon and one was the nb45. The locator flash of the High Noon was considerably faster than the other, I guess up to 50% faster.
    So I asked Henry...
    He said the elf has a hard time keeping time when asleep... in a nutshell, and the elf is asleep between flashes.
    Jun 2014
    Albuquerque, NM
    Quote Originally Posted by Hogokansatsukan View Post
    So I asked Henry...
    Thanks for following up!
    peter yetman's Avatar
    Mar 2014
    North Norfolk UK
    So glad you cleared that one up Dan, thank you.
    It was either that, or something entirely improbable.
    P
    Peter's shopping list:- HDS / Oveready 170N Exec/LE and an Oveready V4 Nichia Drop In. Otherwise I'm content. Want want want, that's me.
    The current computer chip clock keeps lousy time when in the off state, hence the time differences. It's always the elf.
    Eventually we will be firing the elves and replacing them with gnomes.
    We understand that city gnomes are better at keeping time... metro-gnomes.
    Mar 2014
    North Norfolk UK
    Very good! How long did it take to think that one up?
    I hope the elves belong to some sort of Union, there may be trouble ahead...
    Dan, you should be on the stage,,,,
    There's one leaving in 5 minutes.
    P
    Jan 2017
    Dirty Dirty South
    Dan, you are an evil metaphorical genius. There's not enough recognition here for wicked humor. Cheers.
    Sep 2011
    The Alamo City
    So the elves suffer from dyschronometria, but when they do open up the trench coat, how bright is it?
    That is a good question which I forgot to ask Henry, though I'm thinking it has to do with the emitter, as in what kind it is. Don't ask me why I think this... probably too much rum, but I'm thinking it runs on a different system/circuit... though I could be completely full of elf excrement. Wouldn't be the first time.
    Oct 2009
    That is normal if the controller is in one of the deeper sleep states. This is due to the power saving. Normally this feature is not being used for a "locator flash". It is being used for i.e. check a particular external state in a specific timespan. And for this application it is not important if this check is being triggered every let say second or only 0.9s.
    As long as you do not use Hobbits or Orks everything should be fine.
