ArmyTek
Results 1 to 1 of 1
Thread: Upgraded Nextorch TA30 Comes Out!!
    Buttrock Upgraded Nextorch TA30 Comes Out!!
    TA30 2019
    One-Step Strobe Tactical Flashlight
    Classic Succession & All-round Update
    Updates:
    • Max output up to 1300 lumens, more brighter
    • Longest runtime 40 hours for better endurance
    • Coated tempered glass lens for better heat resistance and light transmittance
    • Matches better with the tactical ring FR-1, for safer grip and flexible use
    TA30 2019 continues the design concept of TA30, retaining the patented one-step strobe tactical tail-cap switch, rotational magnetic switch around the tail cap for easy one-handed mode switch and the strike bezel, embedded with superhard Nano-ceramic beads to efficiently break car windows. Its comprehensively upgraded performance is intended to satisfy more tactical needs, with max output up to 1300 lumens, max runtime 40 hours, coated tempered glass lens and matte black finish, etc.
    Detail Comparisions
    ANSI/PLATO FL1 TA30 2019 TA30
    Luminance 20 lm / 200 lm / 1300 lm / momentary on / one-step strobe 15 lm / 160 lm / 1100 lm / momentary on / one-step strobe
    Runtime 40 h / 6 h / 2 h 30 min / - / - 22 h / 5 h / 1 h 45 min / - / -
    Beam Distance 16 m / 84 m / 240 m / - / - 40 m / 82 m / 240 m / - / -
    Materials Source:OSRAM® P9 LED
    Lens: coated tempered glass lens
    Body: aerospace aluminum 6061-T6, Type III hard anodized, matte black surface finish
    Source:CREE® XP-L LED
    Lens: PVC lens
    Body: aerospace aluminum 6061-T6, Type III hard anodized, black surface finish
    Specifications Weight: 99 g (without battery)
    Dimension: 137 mm (length) x 23 mm (body dia.) x 30 mm (head dia.)
    Weight: 90 g (without battery)
    Dimension: 135 mm (length) x 23 mm (body dia.) x 30 mm (head dia.)
    Impact Resistance 2 m 2 m
    Submersible IPX8,2 m IPX8,2 m
    Battery 1x 18650 battery / 2 x CR123A batteries 1x 18650 battery / 2 x CR123A batteries
    Included a lanyard, O rings, a clip a lanyard, O rings, a clip
    Click to Learn More
    http://www.nextorch.com/en/index.php...cal-Flashlight
    FOLLOW US ON FACEBOOK
    LIKE US ON TWITTER
    FIND US ON INSTAGRAM
