Maxtorch
Results 1 to 5 of 5
Thread: Newbie <- need some guidance with my set up
    Unenlightened
    Aug 2019
    Thinking Newbie <- need some guidance with my set up
    Hi there,
    Don't know if this is the right spot to post this but I'm kinda clueless so I could use some help
    Basically what I'm looking for is to make a set up using a re-chargeable battery powering an LED light
    I've got the following 3W Cree LED XPE XP-E R3 3535 SMD High Power LED Chip and a NCR18650B 3.7 v 3400mah 18650 Lithium Rechargeable Battery
    I'm wondering if these are compatible with each other and what kind of components I need to recharge the battery in a safe manner
    Really ANY help in the right direction would be so much appreciated!!!
    Default Re: Newbie <- need some guidance with my set up
    Any particular reason you are wanting to build instead of buy?
    Unenlightened
    Aug 2019
    Quote Originally Posted by lightfooted View Post
    Nope, would prefer to buy instead of build but don't know where to buy such a set up,
    So I'm looking for the LED + Re-chargeable battery + switch + charge jack , no casing but all wired components
    Sorry I didn't get back right away, I guess I am just surprised that you are trying to build something when you would rather buy and the internet is right here. I know I have seen various utility lights that would provide you with all of the internals you are looking for in an already built case. Now if you were trying to build something and just needed the charging board for the battery, okay that's different and I'm assuming you are trying to avoid spending money unnecessarily. Google is...well okay maybe not your friend but in this case a very good acquaintance. Now for that charging circuit...you could locate a small single cell sized pocket power pack for phones and such and just cannibalize it for the board. You could also just use the entire thing as a power supply that you would plug the XP-E into to drive it...although I would suggest a driver board from Mountain Electronics or somewhere to run it through so you don't melt the LED.
    peter yetman's Avatar
    Mar 2014
    North Norfolk UK
    As you are new to this game, why not build a light from an inexpensive kit?
    Here's a guide, plus a link to where to buy the kit.
    Once you have an idea of what actually goes into a light, you can then branch out.
    https://www.fasttech.com/forums/flas...voy-s4-build/1
    P
    Peter's shopping list:- HDS / Oveready 170N Exec/LE and an Oveready V4 Nichia Drop In. Otherwise I'm content. Want want want, that's me.
