Imalent
Results 1 to 6 of 6
Thread: Titanium
    Default Titanium
    Anyone have titanium Eigers/Matterhorns (not sure what they were called back then)?
    Not a lot of info on the site regarding body styles, heads etc.
    I did see that they were only available in a smooth body style.
    Located (possibly) one with an Ultra head.
    Moderator
    archimedes's Avatar
    Nov 2010
    CONUS, top left
    Default Re: Titanium
    Yes, what would you like to know ?
    I'll be glad to answer, if I can.
    ... is the archimedes peak
    Quote Originally Posted by archimedes View Post
    Thank you.
    Wondering which body styles were available; pocket, lug or keychain.
    Also about how old these are as it appears that they weren't offered for very long.
    Moderator
    archimedes's Avatar
    Nov 2010
    CONUS, top left
    As far as I know, the Ti Peaks were only available in smooth + "Key Chain" style.
    I believe the reason for this was, due to material cost and machining difficulty for titanium, these were built from tubing stock.
    As for dates of manufacture, while Peak did do (multiple) limited production runs, titanium models were also available by custom order for quite some time. So identifying a narrow date range is not really possible for most of these (apart from, for example, those specially labeled as the CPF sets, etc)
    Also, be aware that (as you might expect) the threading is consistent with the other versions in the same line, so it is certainly possible to swap tubes and bezels among these.
    Great information. Thank you again.
    Moderator
    archimedes's Avatar
    Nov 2010
    CONUS, top left
    Quote Originally Posted by Vemice View Post
    You are welcome, cheers
