Hi all,
Before posting I searched for "Loose head" on thread titles in all forums, but found only posts relating to high quality lights which had to be returned to the manufacturer for being defective (bad machining of the threads). But moderators please feel free to move this post to a relevant thread if this has already been dealt with.
I've just bought a Blackwater Kite 10180 mini-flashlight (a Cooyoo Quantum clone). The twisty head operation is smooth, but too smooth to my liking. Because there is only one to 1.5 turn between "on" and "head too loose that may fall off", and there is some play in the threads, I would like to make the twist operation a bit harder. Here are the options I see:
- Use a thicker o-ring: might be difficult to find the right diameter and thickness, since it only needs to be marginally thicker
- Put some teflon tape or Loctite threadlocker (the blue one) around the male threads: I'm afraid it will prevent good electrical contact, since these threads are not anodized and used to connect the minus pole of the battery
- Put some conductive "anti-lube" material on the threads or on the o-ring.
