HDS Systems
Results 1 to 3 of 3
Thread: Neutral-warm small light
    Default Neutral-warm small light
    Hey all
    I am looking for a small light, the primary purpose is to "paint light" for night time photography, but it will be used for general outdoor trail walking. I will use the flashlight to add light to something which is otherwise too hard to pick up when shooting a primarily an astro shot. It does not need to be incredibly bright as the exposures are very long, so even a small light (cellphone flashlight) can work. For this reason medium-flood pattern and variable power are two important elements.
    No preference
    2) Budget: An easy question, but you may change your mind after answering the rest! :-)
    Under $50.
    3) Format:
    hand held flashlight
    4) Size:
    Small or Tiny.
    5) Emitter/Light source:
    don't know
    6) Manufacturer:
    want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
    AAA/AA Alkiline or Li Ion
    200-400 lumens max, with at least one varibale power setting, ideally two IE Low-Med-Hi
    Narrow Flood (but being variable would be a great option
    5-20 yards/meters (check out a noise in the backyard)
    ____90-120 minutes (Runtime is moderately important, but still not critical)
    11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
    Any size switch will do.
    2-4 levels (more is fine too, but at least a low-hi option)
    14)Material/Finish/Coating
    Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today’s higher end flashlights).
    15) Water resistance
    don't care
    16) Storage conditions
    Emergency kit (long standby periods)
    Automobile glove-box (wide temperature swings, long standby periods, critical reliability)
    Default Re: Neutral-warm small light
    Wowtac A2S covers most of what you are wanting. It doesn't do 20 yards (60 feet) without using high or turbo mode though as it is not primarily a thrower. It has 5 total modes (3 normal LMH, 2 hidden moonlight/turbo). I got the neutral version but I think it is a little more yellow (warm) than neutral. I think the problem with distance is you could end up with a more pronounced hot spot to get distance at lower light output levels. It is a headlamp but can be removed and used as a right angle flashlight.
    *Flashaholic* ChrisGarrett's Avatar
    Feb 2012
    Miami, Florida
    Emisar D4V2 with Luminous SST 20 at 4000K?
    Chris
    Convoy: S2, S2+, M1, M2, Fenix: P1D, PD32, HL30, ET: D25C Ti, SF: 6P, ZL: SC-600, Klarus: P2A, Jetbeam: BA-20, Icon: Rogue 1, L3: L10, Xeno: E03, ShiningBeam: I-Mini, Olight: i3s, SWM: D40A, M11R, V11R, Maglite: 6Ds, MMs, Solitaires, LaCrosse BC-700, Maha C-9000, XTAR VP2, MP1S, XP1, MC1+, WP2 II, NiteCore i4, v2.
