Klarus
Page 1 of 2 12 LastLast
Results 1 to 30 of 34
Thread: ACEBEAM K75 Review
    Default ACEBEAM K75 Review
    ACE
    BEAM K75
    The ACEBEAM K75 was purchased by NKON: https://eu.nkon.nl/ which I thank for the treatment offered.
    For the technical characteristics it is possible to consult the page: http://www.acebeam.com/k75
    For more information on ACEBEAM you can consult the Official Facebook page: AcebeamWorld
    The packaging:
    The ACEBEAM K75 came to me inside a cardboard box protected by shaped foam. Inside the package besides the ACEBEAM K75 I found a card with some warnings on the use of the K75, four 3100 mAh Acebeam batteries (ARC18650H-310A), handle, bilingual manual, lanyard, 2x O-ring replacement, warranty and warnings.
    Surely the foam protects the torch well, but a hard plastic case like a briefcase would have been a better solution and suitable for the torch class.
    The ACEBEAM K75 is currently the standard LED flashlight with the best performance regarding the length of the beam and therefore of the illuminated meters. The ACEBEAM K75 is equipped with an electronic lock as well as a tripod socket and is recommended, in particular, for searching, saving and long-range lighting. At the center of the deep dish we find the LUMINUS SBT-90 GEN2 LED which thanks to four 18650 Li-ion batteries and a light output of 6300 Lumens manages to illuminate up to a distance of 2500 meters with a peak beam intensity of 1.562.500 candles.
    The ACEBEAM K75 has two modes of use: POWER and ECO. With the first we get the maximum available power of 6300 lumens while with the second we go down to 3000 lumens. The ACEBEAM K75 can also be purchased with the LUMINUS SBT-90 LED with red color.
    Features:
    Max output 6300 lumens
    Max beam distance 2500 meters
    Weight: 843.8g without batteries
    Size: 218mm (Length) x 126mm (Head dia.) x 53mm (Tube dia.)
    Utilizes one LUMINUS SBT-90-GEN2 LED with excellent performance
    Maximum output up to 6300 lumens with monstrous 2500 meters far-reaching beam distance
    ECO and POWER mode switch toggles between Everyday and Search-and-Rescue settings
    Powered by 4 x 18650 rechargeable Li-ion batteries (Excluded)
    4 x ACEBEAM IMR 3100mAh 3.6V 18650 Lithium Ion Batteries (Recommended)
    One-handed, one-button for easy and fast operation
    Highly efficient constant current circuit design (Non-PWM)
    Intelligent temperature controller is used to adjust brightness and prevent overheating
    Rear tripod receptacle brings extra functionality
    Battery level indicator lights for easy power monitoring
    Lockout mode prevents accidental activation
    Toughened ultra-clear mineral glass lens with an anti-reflective coating
    Integrated Precision Digital Optics Technology provides extreme reflector performance
    Sturdy aerospace-grade aluminum body with military grade type III hard-anodized finish
    IPX68 waterproof (2 meters submersible)
    Impact resistance to 1 meter
    NOTE: In order to achieve POWER&ECO modes, the K75 must be installed with 4 x 18650 high drain batteries that can produce at least 10 Amps of current.
    There will be only ECO mode working when use the batteries current <10 Amps.
    POWER Mode:
    Ultra-Low: 7 lumens; 7.5 days
    Low: 120 lumens; 40000cd; 400 meters; 31 hours
    Mid 1: 380 lumens; 99856cd; 632 meters; 16 hours
    Mid 2: 1250 lumens; 289982cd; 1077 meters; 5 hours 15 minutes
    High: 2500 lumens; 559504cd; 1496 meters; 2 hours 15 minutes
    Turbo: 6300 lumens; 1562500cd, 2500 meters; 1 hour 45 minutes
    Strobe: 3000 lumens; 3 hours 15 minutes
    ECO Mode:
    Mid 1: 250 lumens; 69960cd; 529 meters; 21 hours
    Mid 2: 600 lumens; 189660cd; 871 meters; 10 hours 30 minutes
    High: 1700 lumens; 389376cd; 1248 meters; 3 hours 30 minutes
    Turbo: 3000 lumens; 679800cd, 1649 meters; 1 hour 45 minutes
    The Manual :
    The Torch:
    The ACEBEAM K75 shows an imposing body but less than that of other torches of the same type as for example the BLF GT or the Astrolux MF04. The K75 wears well and thanks to the handle included in the package, which can be inserted into the hole for the tripod in two different ways, it is less problematic to keep it in hand when used at maximum power. The quality of construction is remarkable, as in the characteristics of ACEBEAM.
    The ACEBEAM K75 is composed of 4 parts: Head, Body, Battery Holder and Tail.
    The head of the K75 is partly smooth and has a diameter of 126 mm. At the center stands the impressive LED LUMINUS SBT-90 GEN2. The lens is in mineral glass with an anti-reflective coating. On the large head of the torch we find various cooling fins and a slightly crenelated bezel while in the lower part we find the only switch the torch has. There is also a tripod socket and notification LED.
    The ACEBEAM K75's power button is slightly raised and is of a good size. With this switch we're going to completely manage the user interface (UI). The torch has an electronic and manual lock (by slightly unscrewing the tail). The click of the button is silent and is activated with the right pressure.
    The power indicator, on the side of the power button, shows the battery voltage. The low voltage warning remembers when the batteries need to be replaced. This indicator is always illuminated when the ACEBEAM K75 is turned on.
    GREEN: battery voltage is ≥ 12.8V
    CONSTANT RED: battery voltage between 12.8V ~ 12V
    FLASHING RED: battery voltage is <12V
    The K75 turns off when the battery voltage is ≤ 11.2V
    The non-slip knurling on the body of the K75 is rhomboid in shape. Good quality of the writing as good is the quality of the well-lubricated threads.
    The tail cap, in the shape of a "U" has a knurling similar to that present on the body, in the lower part we find the writings of the brand, model, certifications and serial number. It is possible to insert, in the two slots that it has, a cord or a carabiner of a shoulder strap.
    The ACEBEAM K75 is powered by 4 18650 Li-ion batteries inserted in the battery carrier supplied.
    As a contact under the head we find a gold plated spring of moderate thickness. All circuit contact points are gold plated to provide better conductivity and longer life.
    ACEBEAM K75 has tail stand capability.
    ACEBEAM K75 alongside the ACEBEAM K70 and the ACEBEAM X65 Mini.
    An interesting comparison is the one with the BLF GT.
    The peak beam intensity of the ACEBEAM K75 is considerably greater than that of the BLF GT. The ACEBEAM K75 is brighter and has more throw, the BLF GT has a narrower hot spot in addition to having a warmer color temperature.
    User Interface (UI):
    The user interface (UI) of the Acebeam K75 is simple and reflects the one already seen on other torches in the same house. It is managed by just one switch placed on the side. We have 6 levels plus the Strobe available.
    These are the data declared by the house:
    POWER mode:
    Medium 1: 380 lumens; 99856cd; 632 meters; 16 hours
    Mid 2: 1250 lumens; 289982cd; 1077 meters; 5 hours and 15 minutes
    High: 2500 lumens; 559504cd; 1496 meters; 2 hours and 15 minutes
    Turbo: 6300 lumens; 1562500cd, 2500 meters; 1 hour and 45 minutes
    Strobe: 3000 lumens; 3 hours and 15 minutes
    ECO mode:
    Ultra-low: 7 lumens; 7.5 days
    Mid 2: 600 lumens; 189660cd; 871 meters; 10 hours and 30 minutes
    High: 1700 lumens; 389376cd; 1248 meters; 3 hours and 30 minutes
    Turbo: 3000 lumens; 679800cd, 1649 meters; 1 hour and 45 minutes
    ON/OFF
    ON: When the light is OFF, single click the switch to turn ON the light and go to the memorized mode;
    OFF: When the light is ON, single click the switch to turn OFF the light.
    Long Press: 1. When the light is ON, long press the switch to cycle from Low-Mid1-Mid2-Hight, loose the switch to select the mode.
    2. When the light is OFF, long press the switch for 0.5 seconds to activate the Ultra-Low mode.
    Double Click: When the light is ON/OFF, double click the switch to activate Turbo , and every double click to cycle from Turbo and the memorized mode.
    Triple Click: When the light is ON/OFF, triple click the switch to activate Strobe.
    Lock/Unlock
    Lock: When the light is OFF, long press the switch for 5 seconds, the light is locked after 3 timesí flash;
    Unlock: When the light is locked, long press the switch for 5 seconds, the light is unlocked and goes to ultra-low after 2 timesí flash.
    K75 has two modes: POWER mode and ECO mode. Exchange between POWER and ECO:
    when the light is locked, if the light beam changes from dark to bright and goes out after continuous 10 timesí click, it means the light will go to POWER mode after being unlocked; otherwise, the light will go to ECO mode.
    Beam and Runtime:
    The beam of the ACEBEAM K75 is powerful and luminous in its spot and ample and usable in the spill. The color is a beautiful white, surely we are below 6500 į K and there are no strange dominants. I did not notice PWM in the available modes.
    Below is a photo taken in Turbo ECO mode at 3000 lumens. The house is located at a distance of 446 meters.
    The runtimes were performed indoors, with a temperature of around 27 įC.
    For the surveys I used the Dr.Meter LX1330B Luxmeter.
    I should point out that the values expressed by the graphs must be taken, above all, as a reference because they are made with means and environmental conditions different from those used in the laboratory.
    The tests were done using the "new" batteries supplied with the torch (18650 Li-ion ARC18650H-310A 3100 mAh) charged at 4.18V. I also used a small fan to see the pattern of the discharge curve in conditions of forced ventilation.
    Turbo in POWER mode (6300 lm.) Without forced ventilation.
    N.B. In this configuration, at a distance of 10 meters, I measured the candles that were found to be in line with those declared by the house.
    Turbo in POWER mode with and without ventilation (10 min.). It seems from my test that the two curves are similar and that the descent is timed.
    Turbo in ECO mode (3000 lm.) without forced ventilation.
    Turbo in POWER and ECO mode without forced ventilation.
    Finally the complete graph of the tests done including the HIGH level (2500 lm.) In POWER mode without forced ventilation.
    VIDEO Unboxing:
    ACEBEAM k75 in the evening:
    Conclusions:
    The ACEBEAM K75 did not disappoint my expectations. According to what said by ACEBEAM, for the K75 it was used about a year from design to production and every specification was tested for hundreds and thousands of times before release.
    Considering performance in lumens and throw, it remains a torch with acceptable dimensions and weight. Excellent general construction and interesting two POWER and ECO modes of operation. Impressive the beam and therefore the distance reached by the K75 with a very usable and bright side lighting. Surely it is now the reference torch for those looking for a lighting tool for research and rescue to cover long distances. Thank you for reading the review.
    Default Re: ACEBEAM K75 Review
    Thank you for your comprehensive and valuable review of this new king of dedicated led throwers!
    It could be worse. Common dangerous pet animals donít have antlers.
    Iíve got an original BLF GT, itís an impressive light, but Iím slightly underwhelmed by it, at 400-600 yards will the Acebeam provide considerably more visibility? Is a person wasting their money buying the new king every year or two ? How many cd would you predict will be possible in the next 3-5 years, with a usable hot spot not like the W30 ?
    Thanks
    Mar 2006
    Anaheim, CA.
    There is no end to buying the latest and greatest. I still remember when a 100 lumens was a break through where we said can it get brighter back then...LMAO!!!!
    Quote Originally Posted by RBH View Post
    Thanks
    I donít know what it would take to really light up non reflective areas at 600 yards, tree lines at that range are pretty faint with the GT. If they ever produce one that brightly illuminates a dark light absorbing area at that range, I would be absolutely thrilled, I doubt itís ever possible with a $350 flashlight.
    I guess maybe a simple way to sum it all up is, when you shine the GT at something way out there, then you shine the K75 at the same object, is your reaction to the difference between the two, MEH 😐, or WOW !!!!! 😱👀🤪 ?
    *Flashaholic* thermal guy's Avatar
    Jan 2007
    ny
    One thing I have never understood.Unless your using binoculars or a scope why does it matter if a light throws 600 meters? You canít possibly see that far. Can you?
    If i had one day left to live i would want to be at my workplace.Because every day is like a frickin eternity.
    I donít have any problem seeing people, wildlife, vehicles at 600 yards in the daytime on the outskirts of my farm.
    I have searched international forums and I have seen tons of comparative beamshots of BLF GT versus K75, posted by known posters, and I can concretely say that the K75 yields surprisingly more performance than the BLF GT.
    I have not seen this for myself, because I skipped the BLF GT. I can say that the K75 is tops at what is was designed to do: Nice sized hotspot, far away, plenty of lumens.
    Quote Originally Posted by richbuff View Post
    For one minute anyways.
    GT will run its turbo continuously for 2 hours without dropping in output. After 1 minutes the K75 will only have 2/3 the intensity of the GT but still a wider hotspot and more lumen output.
    One minute 🤔, thatís disappointing, a far cry from the stated 1hr 45minutes.
    Quote Originally Posted by twistedraven View Post
    How hard is it to sell a mint GT, been turned on maybe seven or eight times for possibly five or ten minutes each session.
    Nov 2011
    north carolina
    Default best alt battery for acebeam k-75
    just ordered the light, best batteries for it?
    whats the diff in imr and reg lithium ion ?
    Nov 2011
    north carolina
    batteries for this light?
    will flat tops work?
    how about samsung 30 q button tops?
    Quote Originally Posted by ro.ma. View Post
    This instruction is straight from the manual, but I'm not sure of what they're saying. In order to switch between Power and Eco modes, do you click the button 10 times from Locked?
    Flashaholic* torchsarecool's Avatar
    Oct 2014
    lancashire, UK
    To switch between power/eco mode
    1. press and hold button from off for approx 5 seconds to enter lockout mode
    2. Press button 10 times in quick succession, the light will turn on briefly and then either take a step up increasing output (indicating its entering power mode) or will take a step down to reduce output (indicating its entering eco mode)
    (3. Toggle modes by pressing 10 times in quick succession whilst locked out)
    4. Press and hold button to exit lockout mode
    Quote Originally Posted by torchsarecool View Post
    thank you so much!
    Delete
    Quote Originally Posted by Pipper99 View Post
    ~bump~
    Tonight is Sunday night, and when I go to wee early hour Chapel on the hill above town, I will shine my K75 Heavenward, to let all below earth, on earth and above earth know that I am still here.
    You can decide between MEH or WOW after watched this video review by Matt Smith: https://www.youtube.com/watch?v=DQAQigVoNSw&t=438s
    Unenlightened
    Apr 2020
    Only 90 secs of turbo runtime is really little. It makes this light almost useless. What a pity...
    Flashaholic sp5it's Avatar
    Feb 2005
    Poland
    Which cells would be the best for that light?
    Tia, Mike
    My flashlight is bigger than yours...
    Quote Originally Posted by sp5it View Post
    Tia, Mike
    LG3500mah Recommended by my fav light guy.
    i have a k75 and really like it. I find it more useful than my osram lights. Yes, it does step down, but you just donít need max intensity for longer than a quick look far into the distance. Lower levels are plenty bright, itís a useful balance of lumens, candela, throw, and flood. I also like that there isnít a noisy fan, and that it doesnít have moving parts that can break down the road. The only downside is itís physical size.
    Sent from my iPhone using Tapatalk
    K75 was the first light I actually felt scared to use anywhere outside. So much power-- too much power-- in the hands of one person.
    May 2018
    USA
    I've owned one for several months now. I'm on the fence about sending mine to Vinh to be modded, the wow factor hasn't worn off yet. Maybe then.
    One overlooked thing about the K75 is it has a wonderful low mode that is perfect for up close without blasting your eyes.
    Feb 2005
    Poland
    Is flat top LG MJ1 working in K75?
    I don't know. My guess is that for more performance, use lower capacity cells, and for more runtime, use higher capacity cells.
    For less performance, use smaller flashlights, and for most performance, use larger flashlights.
    Feb 2005
    Poland
    So if you don't know why you recommend that cells? Those won't work in K75.
    Mike
