XTAR Multipurpose Battery Charger for Size 21700 Batteries
XTAR Light
Vendor
China
What is Vaping? Vaping is the act of inhaling and exhaling an aerosol produced by a vaping product, such as an electronic cigarette. Vaping doesn't require burning like cigarette smoking. The device heats a liquid into a vapour, which then turns into aerosol.
Vaping devices are usually battery-powered. They may come with removable parts. So charge an extra set of batteries in your external charger, and you won't have to wait for your SMOK mod to charge. This is also great for your keeping your mod in good condition. USB ports on vape mods tend to break easily
August 21, 2019 ---- XTAR, a high and new technology industry, released today the XTAR battery charger --- PB2S Type-C Dual-role Fast Charger and Power Bank 2 in 1 product. It's an updated version of PB2 that already launched in 2018. The PB2S is able to charge 20700/21700 batteries which means it could has larger capacity when it used as power bank.
Not only an intelligent Li-ion battery charger, but also a portable power bank. That is to say, This PB2S power bank can charge your battery! How to do? Just take off its magnetic cover and insert your battery, The XTAR PB2S support 18650 to 21700 size battery! Which is ahead of our competitors like Golisi, Nitecore, Efest...
The PB2S built with high-quality metal contacts that contact the battery's negative pole can last for more than 30,000 times and also reduce resistance and maximize the battery lifespan. What's more, there is a ribbon in the slot, which makes it easier for inserting and removing the batteries, solving the scraping issue caused by violent disassembly.
The high-precision MCU makes end-of charge voltage up to±0.05V, and the charger will automatically stop charging after fully charged batteries, which is safe and worry-free.
XTAR products and PB2S are sold at Amazon, eBay, Shopee & Aliexpress. To learn more about PB2S, please click: PB2S or visit:
[url]https://www.ebay.com/itm/333307299061[/URL]
XTAR Light
Vendor
China
Ideal Battery Packs for Your Outdoor Activities
When you're miles from anywhere, a portable power bank can quickly become your very best friend
Going on a backpacking or camping trip once meant leaving all of your electronic devices behind in favor of escaping the hustle and bustle of modern life for a little while. We're more dependent on our portable devices than ever, but we always rely on the batteries that power them. To avoid running completely dry, it's best to carry a portable battery pack. Here is my recommendation for you.
The PB2S not only an intelligent Li-ion battery charger, but also a portable power bank, charge your mobile devices anywhere and anytime in outdoors and it features a TYPE-C and USB-C ports, which can both be used for output and charge two external devices at the same time, more convenient for outdoor usage.
The charger should be able to fit neatly in the same or smaller space as your cellphone like, Samsung Galaxy S10 or iPhone XS. Otherwise, you'll have one in your pocket while carrying the other in your hand — not cool! However, PB2S's net weight only for 85g, lightweight to carry and easy to operate. You can even DIY the capacity of the power bank up to 10000mAh+. If there are enough batteries, PB2S is your outdoor charging station.
XTAR products and PB2S are sold at Amazon, eBay, Shopee & Aliexpress. To learn more about PB2S, please click: PB2S or visit: [url]www.xtar.cc[/URL]
XTAR Light
Vendor
China
XTAR PB2S, Type-C Dual-role Fast Charger and Power Bank
August 20, 2019 ---- XTAR, a high and new technology industry, released today the XTAR battery charger --- PB2S Type-C Dual-role Fast Charger and Power Bank 2 in 1 product. It's an updated version of PB2 that already launched in 2018. The PB2S is able to charge 20700/21700 batteries which means it could has larger capacity when it used as power bank.
"As you can see the market, there are different protocols among the phones so that also means it is difficult to produce a product that is compatible with all the PD devices. We have spent much time on product development to make a better user experience for our customers," David CEO of XTAT said.
What's more, XTAR PB2S support the most popular QC3.0+PD3.0 dual-protocol fast charging, compatible with most fast-charging adapters of most phones on the market, easy for match and charge their smartphone on the go using this portable charger. Also an ideal charger for your vape pods/mods. Besides, PB2S has 4 optional colors like Black, Red, Blue and Orange.
XTAR Light
Vendor
China
[FONT=&quot]Hello.
Today's review will be devoted to the charger with the option of a power bank (or a power bank which is also a charger) PB2S.[/FONT]
[FONT=&quot]So, what's interesting in this device?
Well ... it's not a very versatile charger, and a very interesting power bank.
Let's start the review, I'll explain everything there.
Go? The device comes in a small cardboard box, the equipment is minimal (instructions, yes USB-> USB type C cable). I am glad that the cable supports data transfer.[/FONT]
[FONT=&quot]The device can be purchased in four color options; I got a red one for the review. There is a soft touch coating, the screen is matte, scratch resistance is noted. A little bit about the operation of the device. The type-c input is also an output, the charger is capable of charging two devices simultaneously.
The button on the charger changes the readings displayed on the display, as well as activates the output of low current (for charging fitness bracelets, for example, which the device in normal mode may not "feel" and ultimately not charge). The button does not change the modes of the charge current as well as the different outputs of the device. What am I doing? And the fact that the battery charge current depends only on the connected power supply, and the user can not affect this. So if there are a lot of 2 amperes per channel - connect to a weaker power supply.
During charging, you can connect / disconnect rechargeable batteries. Also, while the device is operating in power bank mode, you can change the installed batteries, the output current in this case does not interrupt (of course, if at least one battery is installed).[/FONT]
[FONT=&quot]The device is compatible with protected and unprotected 18650 batteries and also unprotected 21700. The 18650 batteries in the device "walk" with active shaking, contact is sometimes broken. The protected 21700 cannot be installed; the length is great.
The magnetic cap holds tightly and securely, you can lift the device with the batteries installed, it will not come off. The device (and screen) is in operation. A few measurements: An unprotected battery device discharged up to 3.27 volts. When connecting powerful devices, I found that the voltage drops but the device "tries" to give out more current than it can - with the declared 5 volts 2 amperes, I saw 4.4 volts 2.2 amperes. On the one hand, almost 10 watts, and on the other hand, 12% of the deviation from 5 volts is too big.[/FONT]
[FONT=&quot]The device charges unprotected batteries up to 4.16-4.18 volts.
QC3.0 output works correctly.[/FONT]
Mishanchik
Russia
Alas, but Xtar PB2S not full compatible with specification Quick Charge 3.0 18W
QC 3.0:
5V-3A ( 2.7A with PB2S )
9V-2A ( 1.7A with PB2S )
12V-1.5A ( 1.2A with PB2S )
It is very unfortunate that the device does not meet the specifications Quick Charge 3.0 and numbers on its packaging.
