Wuben
Results 1 to 14 of 14
Thread: Surefire Oveready modded 6P/ 9P/ C2 Glass lens replacement
    Dec 2018
    Assachusetts
    Default Surefire Oveready modded 6P/ 9P/ C2 Glass lens replacement
    Hello CPF!
    I have a few Oveready modded Surefires, namely a bored C2 and a bored 9P that both came with frosted lenses. I bought clear lenses from Vinh, but they seem far too thin to fit in place of the frosted lens.
    SO, in looking for a replacement, the only source I can find on line is VIA Lumensfactory from China. I'm not against this route, but it seems crazy to me that it's the only option. Ebay has a few listings for some 2.9mm thick glass, where LumensFactory states theirs is 3.4mm, which is what I feel like is the "right" glass for my host given the thinner option was evidently, too thin. Also it seems O-rings are rather hard to find, unless they come with the lenses.... any advice?
    SO CPF where should I get my replacement glass for my newer model surefires? How thick should it be? Is there something I am missing about replacement of OR-modded Surefires? OR themselves are OOS for those lenses.
    Thanks in advance!
    Dec 2008
    Washington
    Default Re: Surefire Oveready modded 6P/ 9P/ C2 Glass lens replacement
    OR looks like they have the borofloat/pyrex lenses available for Z44 bezels...they are out of UCL lenses...
    Moderator
    Dec 2008
    Penn's Woods
    Flashlightlens.com is another good source, but they're closed until the 13th of September...
    But February made me shiver
    with every paper I delivered.
    Mar 2006
    Anaheim, CA.
    Flashaholic* Timothybil's Avatar
    Nov 2007
    The great state of Iowa
    Quote Originally Posted by scout24 View Post
    The last few times I checked it seemed like the were closing out their lenses, since there were a lot of the popular ones that were 'not in stock'. I wanted spare lenses for my G2 and 6P. I got the 6P lens from Lumens Factory, and the G2 from EDCPlus.
    EDCPlus.com
    Remember, Two is One, and One is None!.
    Moderator
    Dec 2008
    Penn's Woods
    Thanks for the heads up, I haven't ordered from them recently. They had been a long time go-to in the past. Hope they stay around...
    Flashaholic* Nichia!'s Avatar
    Dec 2016
    Nowhere
    Quote Originally Posted by Timothybil View Post
    EDCPlus.com
    Which one is better quality lumen factory or edc plus?
    Nov 2007
    Quote Originally Posted by Nichia! View Post
    Visually, they both appear to be high quality. Since I have no means of actually testing the lenses, that's about all I can say. It's really not an issue, because each one only sells the one type of lens, so there can be no face-to-face comparison.
    Dec 2018
    Assachusetts
    Thank you all kindly for your response, I will be checking out those other sites. Much appreciated!
    Dec 2018
    Assachusetts
    Follow up question: are they the same thickness? Do you happen to know the thickness dimension?
    Dec 2016
    Nowhere
    Quote Originally Posted by dotCPF View Post
    I have the same question
    Nov 2007
    No, they are of different thicknesses. If you look at the sites mentioned they will give the dimensions. Also, the lenses are not interchangeable with each other. The thicker one will not fit into the other light, and the thinner one will not seal properly do to the gap created.
    Dec 2016
    Nowhere
    Which one you recommend for the Surefire 6p ?
    Dec 2018
    Assachusetts
    OK great thank you kindly Timothybil. I am just hesitant of the accuracy of some of those products on the pages. I have gone ahead and ordered the thicker "3.4mm" versions from Lumensfactory.
    Again, thank you very much for following up.
    RE: Nichia!
    I have some thinner lenses from Vinh that did not work in either my 9P or my C2. I would assume that these are the 2.9mm versions, that indeed leave too much space. FWIW
