Need a flashlight for my parents
bluelunar
The power was out for a few hours at my parents house this morning due to Hurricane Dorian. Realized they didn't own a flashlight. Luckily the power was restored after about 3 hours and they used my Ozark Trail Lantern I had left in the garage last time I was there. I need a flashlight that is easy to use by my elderly parents during power outages. Preferably single mode or at most high/low so they be confused with turning it on. Also preferably that uses standard batteries (AA/D/C). I suppose it doesn't have to be a flashlight. The Ozark Trail Lantern seemed to fit the job, I may get one for them. Still I want like to hear any suggestions. Thanks.
____I would like to purchase the light in person from a brick and mortar store. I am located in ______________.
____This will be mail-order or Online (location doesn't matter).
Open to buying it anywhere
2) Budget: An easy question, but you may change your mind after answering the rest! :)
____I don't know yet
__X_Up to $25.
____Up to $50.
____Up to $100.
____Up to $200.
____Up to $300.
____Essentially unlimited.
3) Format:
_X__I am not sure, please help me decide.
____I want a flashlight (hand held/self contained).
____I want a self-contained headlamp.
____I want a headlamp with an external pack/power source.
____I want a mounted light (typically for a bicycle or vehicle)
____I want a lantern/area light.
____I want a portable spotlight (it may have an external power source).
____Other ____________________________________________
4) Size:
____MICRO - Keychain size.
____TINY - Every day carry (2-4 inches).
__X_SMALL - Every day carry (4-7 inches).
____MEDIUM - Holster/belt ring carry. (>7 inches)
____LARGE - Big enough to need its own travel case.
____I don't know/I don't care.
5) Emitter/Light source:
_X__LED (known for efficiency, longevity, and compactness)
____I don't know.
6) Manufacturer:
_X__I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
____I would like a light from a specialty manufacturer (Possibly limited run/Custom).
____I am interested in assembling my own components. (for example a "host" or flashlight body from one manufacturer, and a "drop-in" emitter from another source).
_X__I intend to use "Primary"/Disposable Alkaline batteries based on the usual AAA/AA/C/D sized cells common to most stores.
____I intend to use "Primary"/Disposable Lithium batteries based on the usual AAA/AA/C/D and CR123 sized cells common to most stores (often a cold weather or long storage choice).
____I intend to use Rechargeable cells (NiMH or NiCD) based on the usual AAA/AA/C/D sized cells common to most stores.
____I intend to use Rechargeable cells based on less common formats (18500 or 18650 Li-Ion, RCR123, et-al).
____I want a light with an integrated rechargeable battery pack.
____I don't know/I need more information on power sources.
____I want a light that plugs directly into the wall (literally with prongs built into the light)
____I want a light that has a recharging adapter (your typical "wall wart")
____I want a light that snaps into a cradle (usually mounted on a wall)
____I want a separate/stand-alone charger (this involves removing the batteries to charge)
____I don't care
____I want to navigate a dark room or read a map (1-10 lumens).
_X__I want an indoor "blackout" light (15-50 lumens)
____I want to confidently walk around an unlit/unpaved rural area (60-150 lumens).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
____I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
____I want search and rescue type illumination (800+ lumens).
_X__SPECIAL NOTE: Burst/Turbo mode Category - There are several lights that will run at a super bright maximum for a very limited period (usually 5-10 minutes) and then will "step-down" to a lower level for thermal control. Check here if this is acceptable.
____All Flood: I am doing "arms length" tasks like reading and campsite cooking.
____Wide Flood: I want a defined flood area for semi-close tasks like after-dark campsite tasks or working on a car.
__X_Narrow Flood: I want a sharply defined flood area that will project some distance for tasks like trail walking.
____Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
____Narrow Throw: I want a beam with a very tight "hot center" and minimal "side-spill". Good for distance viewing, fog, and looking through dense undergrowth.
____Turbohead: I want a far-distance projector with a sharply focused spot of light and minimal or zero side-spill. Good for extreme distance and impressing your friends.
____Less than 1 yard/meter (reading, other close work)
_X__Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
____5-20 yards/meters (check out a noise in the backyard)
____150+ yards (I am searching from a helicopter)
____30-60 minutes (I have plenty of batteries just ready to be changed)
_X__90-120 minutes (Runtime is moderately important, but still not critical)
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
_X__Not Important (A "night-stand" light).
____Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don't know.
_X__Any size switch will do.
____I need a BIG switch (I'll be using gloves or have very large hands or coordination issues).
____I want a forward clicky (Helpful for momentary activation and signaling).
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
____I want a body mounted switch (near the head, like on a Maglite).
____I want a tail mounted switch (found on the majority of today's high end lights).
____I want a remote switch (usually found on high-end bicycle headlights)
____I don't care.
____I don't know.
__X_A simple on-off with only one output level is fine for me.
__X_I want 2 light levels. (Brighter/short runtime and Dimmer/long runtime.)
____I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a selector ring.
____I want a strobe mode. (Oscillating pattern to confuse/blind aka "Police Mode")
____I want SOS mode. (blinks in ...---... emergency pattern)
____I want a beacon mode. (Regular flashes at full power to show location.)
____I don't care.
____I don't know.
14)Material/Finish/Coating
____Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's higher end flashlights).
____Stainless steel (durable, but much heavier than aluminum)
____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
_X__I don't care.
____I don't know.
15) Water resistance
_X__None needed
____IPX4 (Splash resistant)
____IPX7 (Waterproof to 1 meter/30min)
____IPX8 (Submersible to greater than 1 meter for 4 hours)
16) Storage conditions
_X__In house (temperature/climate controlled environment)
____Emergency kit (long standby periods)
____Automobile glove-box (wide temperature swings, long standby periods, critical reliability)
____Other_________________________________________ ____
____"Hybrid" light (bright incandescent combined with long running LEDs)
____Pocket/belt clip
____Holster
____Wrist/Neck Lanyard
____Crenulated bezel
____Non-sparking, Intrinsically Safe (IS) for use in explosive environments
Dicaeopolis
Just about any Maglite should meet their needs. Maglites are at most hardware stores.
xxo
Maglites are a good bet., I would suggest a couple of 2 AAA Mini Mags, simple twisty/single mode operation, light weight and easy to carry, fairly bright (100 lumens) without being too bright with a great beam pattern (big spill with a good throwy hot spot). These can be dropped in a mug and ceiling bounced for a lantern effect or they can be used in Mag's candle mode by removing the head and using it as a stand. These can be had for $15 at home depot. Energizer L92 ultimate lithium batteries would be best for storage since they don't leak and have a 20 year self life.
desertrunner
Banned
Easy- the Browning Crossfire. It's inexpensive, durable and uses dual fuel. Also has high and low only. Lastly, it's USB rechargeable, very easy to use.
Julian Holtz
Germany
Question: What do most people need flashlights for?
Answer: To store dead batteries.
Pun aside, this is the truth very often sadly. And to make matters worse, alkaline cells tend to leak. So you must either store your batteries outside the flashlight, and find them and insert them in the dark, or, if you put alkalines in the light last year or so, you need to remove the leaking cells, and find and put in new ones (in the dark) only to find out that the acid corroded the contacts and the darn thing does not work.
I would therefore recommend a USB-rechargeable light with a Lithium battery. Namely this one with the 4200K T6-4C option.
https://www.banggood.com/de/2_5A-Co...ble-Super-Bight-EDC-Flashlight-p-1319631.html
The battery:
https://www.banggood.com/1PC-Keeppo...HG2-3_7v-3000mah-Li-ion-Battery-p-995424.html
This (4200K) will be a warmer tint which does not look so harsh and brings out the colors better. You will never have to worry about the battery supply as you can recharge it with a simple phone charger, the battery will not drain on it's own or leak, it will last many hours in the lower modes and it is easy to operate. Try it, your parents will love it.
LeanBurn
Alberta
Fenix E12 with an Eneloop or other reputable rechargeable....Although it has 3 modes they are all extremely useful and always starts in low, very simple to operate.
Keitho
CO, USA
Very good point. I have another antidote for going back in a couple years to find the Maglite or whatever with dead, leaking batteries--get them a light that also has another function that they'll use. Some powerbanks have lights built in; I have a car jump-starter with a flashlight built in that stays plugged in the car; there are "night lights" that stay plugged in, but have a battery backup and can be used as a flashlight; there are outdoor lights with mini built-in solar panels that they could grab and bring indoors if the power went out; the obvious one is a cellphone if they have one--put a big button/widget on your parents' phones for "flashlight" (and get them a USB powerbank). Or, get them some battery powered task lighting--a supplemental 'fridge light, sewing machine light, motion-activated closet light or pantry light--when the batteries get low, they will notice it and replace them with fresh ones.
Oh yeah, don't underestimate "candlepower" as well (if they are having trouble with dexterity due to age, get them a nice, safe candelabra and an easy-to-use lighter).
RWT1405
PA
I don't know about the parents of those that have suggested rechargeable batteries, but my parents would NEVER recharge them, and they would be a complete waste of money and effort.
If it was me, and actually what I did do, for my parents, is use Lithium AA's (non-rechargeable) in an appropriate flashlight.
Then I leave them the appropriate amount for back-up, in case it dies before I get there to visit.
Remember KISS, Keep It Simple Stupid!
But then, I guess that's just me.
bluelunar
I agree. I'm probably going to go with a 2xAA Maglite with lithium batteries in them. If the lithiums run out during an extended outage, they'll be able to find AA's easily. They have a box of spare AA's anyways for the various electronics around the house.
Timothybil
The great state of Misery (Missouri)
Eveready makes several lights of varying brightness and function that would work well. I have the Fusion Lantern (4/8 AA) which works great as an area light. They have several smaller ones that are flashlight only, or flashlight/small lantern. Nitecore has several lanterns as well, but most of them are USB rechargeable. They do have one that is USB, but can also take a couple AA cells as well. The LA10/LA12 are single AA or AAA lanterns in a lipstick form factor. Collapsed they can be used as a flashlight, opened up they are a small lantern ideal for immediate area lighting.
RWT1405
PA
I think that's an excellent choice!
Good luck with your plan!
Poppy
Northern New Jersey
I gave my Dad a 3D maglight, and each year I give him some D cells.
I gave him a Ryobi lantern that will run on the 18V One+ batteries (It will also act as a power bank)
I gave him a 3D cell lantern similar to the Ozark Trail IIRC a Home Depot Defiant. I hope they come back out with them.
Perhaps most importantly, I gave him a few Instant ON Power failure lights. They stay plugged into an outlet, charging, and when the power goes out, they come on. They can be had for less than $10. Some act as a night-light and are always on, some have a light sensor and go off during daylight (depending upon where they are placed). When the power goes out your folks can be instant cave like darkness, tripping over stuff trying to get to and find whatever light/lanterns you gave them.
I strongly suggest that you get a few power failure lights. They can be positioned so that they throw some light into more than one room. I have one plugged into an extension cord lying on top of my refrigerator. The kitchen, dining room, and living room all get some light from it. Another one connected to another extension cord lies on top of the entertainment unit in the living room and throws light into the living room, dining room, and hallway to the bathroom and bedrooms.
There should be one in the garage, and at least one in the basement. Instant darkness and steps do not make a good combination.
SleepyInTheSun
Denver
This.
Many parents (or grandparents...) have a nightlight in the bathroom anyway to avoid general time fall hazards, makes good sense to me to replace with something that comes on automatically during a power outage. We have some from GE but there are lots of good options. Additional plus is not only do you have light, it's a familiar pattern due to routine nightlight use. Sometimes when the lights go out a bit of routine goes a long way.
Also good call on lithium primaries.
PartyPete
The Wowtac A1 is decently bright at 550 lumens and $20 on Amazon, sometimes less with promos. Comes with a USB rechargeable battery.
It's a good value and I think the battery is simple enough to charge to be a decent solution for most.
LetThereBeLight!
I would only add to the suggestions here that you give each parent a Nitecore Tube
(new version out soon with 55 lumens) on a lanyard.
OR give each a rechargeable Headlamp, or one that takes AAA batteries.
These would be in addition to whatever you decide not only because of their utility but because as often is stated here, two is one and one is none.
- LetThereBeLight!
CL97405
We had a storm and extended power outage last winter and my grandmother lives out in the country. I brought her a half-dozen cheapie single-AA flashlights with Eneloops in each one. She has three in the kitchen drawer and one in each nightstand. They tailstand so they can easily light up a room, and I swap out the batteries whenever I visit. Cheap solution and she will always have one when she needs it.
flatline
Tennessee
For $6, get them a 2-pack of the Eveready 1D flashlights. These lights are super simple to use, will tail stand, are anti-roll, and get crazy long run-time off of anything you feed them.
They come with a D cell, which, quite frankly, your folks will probably never use up. But if they do, any D, C, AA, or AAA cell that they can scrounge up will work, probably even "dead" ones. Seriously, I take "dead" AAA alkaline cells out of my kids' toys and get 20+ hours of run-time from them (I use them as night lights...maybe 3-5 lumen output on these "dead" cells).
Don't waste money on nicer lights with multiple modes and tail switches that you're folks will never use. Just get them a 2-pack of these and put it under the kitchen sink or someplace out of the way that your folks will know to find them.
sonofjesse
Earth
Costco has the 3 pack of AAA lights (each light is 500 lumens) for 20 dollars total. These work good, put in lithums. This should be a good bang for the buck for the parents, and still accepts normal batteries.
