ArmyTek
Results 1 to 26 of 26
Thread: One month runtime
    Au One month runtime
    I'm looking for a flashlight with a runtime of one month. It should run on a single AA or 18650 cell. The light output should be high enough to navigate complete dark rooms.
    This might sound a little crazy but I'm really curious if there is something like this out there.
    Moderator
    archimedes's Avatar
    Nov 2010
    CONUS, top left
    Default Re: One month runtime
    So ... 24 hrs/day × 31 days/mo = 744 hours ?
    Sure, I'll link up a few below ...
    Well over that duration (on CR123A)
    https://www.candlepowerforums.com/vb...X5-Red-vs-24-7
    Pretty close (on CR123A)
    https://www.candlepowerforums.com/vb...=1#post3689105
    Extrapolated results from AAAA to AA (some well into the weeks range)
    https://www.candlepowerforums.com/vb...=1#post4460068
    Alkaline AA
    http://www.candlepowerforums.com/vb/...t-Runtime-Test
    Two weeks on lithium AA
    http://www.candlepowerforums.com/vb/...nlight+runtime
    Three weeks for "legacy" HDS Clicky (on CR123A)
    https://www.candlepowerforums.com/vb...=1#post4490051
    Some 18650 torches
    http://www.candlepowerforums.com/vb/...-day-Challenge
    HDS Twisty (on 18650)
    https://www.candlepowerforums.com/vb...=1#post3553379
    It depends on how well your dark-adapted vision might be, and what you would consider adequate output.
    ... is the archimedes peak
    Apr 2016
    Massachusetts
    With dark adjusted eyes you could probably navigate completely dark rooms with moonlight mode that are available on many of the main stream of quality lights manufacturers you'll see here on CPF. With a single cell flashlight an 18650 battery could last that long or even longer depending on the specific light you get. Check any of the specs of a light you have an interest in and it should give a run time per lumen output to give a general idea of how long you can expect to get depending on the specific battery you put in the light. There are many choices to look at.
    Dec 2007
    California Republic
    It's a fun thought experiment, but bear in mind that under real-world power outage/third world conditions you only use a flashlight ~5 hours a day total; as it was in the time before flashlights, you use ambient daylight during the day, only when you use the bathroom or after sunset will a light source see any use. You'll find yourself naturally going to bed earlier and waking at sunrise without artificial light, which is to the benefit of the battery life of any artificial lights you're using.
    The bigger battery life concern for emergency outages is the battery-powered radio - if you have any concern for getting information and/or improving morale, this is left on nonstop during waking hours and sometimes beyond that. Larger cells are king here, as a modern 2-3D cell unit [on alkalines] will give you 200-300 hours of runtime.
    peter yetman's Avatar
    Mar 2014
    North Norfolk UK
    Quote Originally Posted by archimedes View Post
    Well done Arch, I've been racking my brains, and thinking Malkoff M31LLLLLLL, but I was really thinking HDS.
    P
    Peter's shopping list:- HDS / Oveready 170N Exec/LE and an Oveready V4 Nichia Drop In. Otherwise I'm content. Want want want, that's me.
    Moderator
    archimedes's Avatar
    Nov 2010
    CONUS, top left
    I *think* the lowest M61 has been the LLLL ( and related, like the NLLLL and N219 LLLL ? )
    I do see a couple of posts discussing an M61LLLLL but I sort of wonder if that might be a typo, or stuck keypress
    Administrator Kestrel's Avatar
    Oct 2007
    Willamette Valley, OR
    Easy, BOSS70 w/ 1x18650; could probably program it to stretch the total runtime to a number of months if desired.
    https://www.candlepowerforums.com/vb...p-v5)-programs
    But how could a true aficionado do without that fine EDC for that extended of a timeframe ?
    Plugging in 1xAA or 1x18650 and 744 hours minimum finds 126 models in my database. Almost all of these are well under 1 lumen. Enough to read by or not trip over things in the dark. Some highlights:
    • The least expensive is the $20 Wowtac A2 with a 45 day firefly
    • Most Armyteks and all Zebralights have a firefly mode that can run for 2 months
    • Thrunite has a bunch for good prices
    • Most of the serious brands have several models with a firefly: Olight, Nitecore, Acebeam, Eagletac, Klarus, Rofis
    • Fenix hates firefly modes. They only have 1 light that qualifies: the UC35 V2.0
    Try the largest, fastest, most flexible flashlight search engine: parametrek.com
    41 brands, 2124 models and still growing!
    NEW: battery search, sleeping pads search
    Moderator
    Dec 2008
    Penn's Woods
    Kestrel- (buy two?)
    Wildflower seeds on the sand and stone
    May the four winds blow you safely home...
    Under ground bunker light quest thread here.……post Cold War.
    I'll try a Yuji in a 2 cell Maglite ML25 incan version, using alkalines then perhaps see how many weeks a pair of c sized Imedions would last.
    John 3:16
    Mar 2014
    North Norfolk UK
    Deliberate typo.
    P
    Flashaholic* nightshade's Avatar
    Mar 2004
    Adrift
    My favorite pick: Pak-Lite with a 6 AA to 9 Volt battery adapter. Easy to improvise a waterproof container, even one that will float with the Pak-Lite and adapter inside.
    Moderator
    Dec 2008
    Penn's Woods
    Default Re: casino real money games
    Plus one on the Pak-Lite, nightshade. I did a runtime test on one using a lithium 9v. Their ratings are conservative. As far as the M61LLLL goes, I'll find the post but I think I got one of the first ones back in the day...
    Edit- Oops! It was an M61LLL as custom order from Gene back in 2012. Idea belonged to Leon2245, I just made the phone call. The Pak-lite I ran was on a Duracell, I could still see past my feet to walk around the house after 89 days on low. No further than that, but enough light to not step on legos or the cat...
    Apr 2006
    USA
    multiholle --
    You've been a CPF member for * SIX YEARS *,
    and yet this is only your 4th posting ? ? ?
    Guess you've been giving this question
    a WHOLE LOT of thought . . . . .
    Anyway --
    My answer would be a Zebralight SC-5
    (either Mark 1 or Mark 2 version is fine).
    This is a single-cell AA Energizer L91 ultimate lithium
    I can personally attest that even MY tired old eyes
    (66 years, with cataract surgeries, and a
    detached retina) can (if dark-adapted)
    manage to find my way around a totally dark room
    without bumping into things.
    I've even managed to complete a crossword puzzle,
    Sudoku puzzle, and the Celebrity Cypher
    from my daily newspaper !
    Quite an eye-opening experience for me.
    (sorry for the pun)
    _
    2 AA batteries, but original Minimag with a white 3mm LED replacing the original bulb, over a year of usable light (15th of May 2018-15th of May 2019), i had to stop the test due to battery leakage.
    Mar 2014
    North Norfolk UK
    Impressive.
    P
    +1000 all Zebralights. One of the best candle modes of the factory lights. Manker too, but Zebralight quality is a probably a step above Manker.
    Fenix UC35 v2.0 is rated at 800 hours at 1 lumen on a single 3500mAh 18650.
    Streamlight ProTac HL - SureFire P2X Fury - Fenix PD35 v2.0 - Lumintop Tool AA 2.0 - Fenix PD25 - NiteCore SRT7GT
    Flashaholic* LeanBurn's Avatar
    Feb 2010
    Alberta
    Thrunite TN4A will run 80 days in 0.5L firefly mode.
    THRUNITE > Archer1AV2|TiS|TH20|TN4A Hi...all in neutral white
    YUJILEDS BC Series 95+ HiCRI
    > Sofirn C01|Dorcy Penlight (Yuji modded)
    XTARVC4, LCTBC500, Amaloops, 1999 MAG-LITE 2D Incandescent(glass lens) Petzl Tikkina 80L ..... E01
    Okay, I will play.
    Zebralight runs 2928 hours on moonlight, which is way more than enough light for fumbling around the house in the dark.
    - SC64w 18650 XHP35 Neutral White Flashlight
    Moderator
    archimedes's Avatar
    Nov 2010
    CONUS, top left
    Quote Originally Posted by JimIslander View Post
    .... Zebralight runs 2928 hours on moonlight, which is way more than enough light for fumbling around the house in the dark.
    So, four months, nice
    Is that per published spec, or calculated, or as a runtime tested result ?
    Published spec for the model I posted. Similar specs for several of their 18650 lights. One of the things I like the most about Zebralights is their incredible range of lumens, from blinding high to night vision protecting lows that run forever.
    Additionally, you can program the light to come on at any level you like, still have double click for high, single click for low, long click for med, or whatever combo you want. Could be LLL, LHM, anything you like.
    Moderator
    archimedes's Avatar
    Nov 2010
    CONUS, top left
    Published spec for the model I posted....
    The reason I asked was that CPF member @reppans is a sublumen expert and has found fairly wide variance between published spec and tested results (one of his posts I had linked up earlier)
    If I remember correctly, ZL was one where the published efficiency was different than the measured efficiency
    I don't doubt that it will run more than a month continuous, however.
    Thanks for all the input. I just realized that I own a Zebralight SC5w Mk II with moonlight mode. I never really used those modes.
    L1 3.2 Lm (4.2 days) or L2 1.1 Lm (14 days) / 0.33 Lm (50 days) / 0.09 Lm (4.3 months)
    Mar 2014
    North Norfolk UK
    How annoying, no excuse to buy a new light then.
    P
    Quote Originally Posted by peter yetman View Post
    P
    Come on man, that's a very defeatist view of looking at it. You can get a new one for testing, another tint, another manufacturer, or even one more of the same as a backup just in case.
