Maxtorch
Results 1 to 12 of 12
Thread: HDS High Noon vs Malkoff Bodyguard CR123 Batt
    Default HDS High Noon vs Malkoff Bodyguard CR123 Batt
    Recently had an opportunity to take a few pics. It is a bit impromptu. Ask me any questions you might have.
    http://imgur.com/gallery/NCAKXj4
    Sorry, for the many posts. I am not tech savvy and tried to do my best to share.
    Default Re: HDS High Noon vs Malkoff Bodyguard CR123 Batt
    usdiver's Avatar
    Feb 2004
    In the Sticks
    Which do you prefer
    Donít Tread On Me
    For Everyday carry HDS High Noon. Mainly because of this particular tint is pleasant and throwy.
    The Malkoff seems to be specialized for security or bodyguards. It puts out a blinding amount of light for a brief period. Thats repeatable many times all you need to do is cycle the light.
    I am not in any security or Law enforcement position. So I would stick a MDC head on the Bodyguard body with a Low-medium- High head and you have a serious HDS contender in my opinion.
    RCS1300's Avatar
    Aug 2012
    Stamford, CT
    I was always attracted to Malkoff because I like to support USA individuals and Companies. HDS is preferred for me mostly because of the fantastic proprietary technology packed into the light.
    Although, I do have my eye on the Hound Dog and Super Hound Dog.
    I wish I could afford to buy several HDS to spread around in cars and go bags. I ended up with Malkoff in all my secondary locations like emergency back packs and cars. HDS is always in my pocket but I can't afford HDS just to sprinkle around like I did with Malkoff Flashlights.
    Moderator
    archimedes's Avatar
    Nov 2010
    CONUS, top left
    Quote Originally Posted by dorikinhajime View Post
    For quite a long run, retail pricing of HDS roughly kept pace with output increases due to emitter tech advancements, at roughly about ~ $1 / lumen (max output)
    What I mean is when the HDS (Ra) 100 was new, it cost ~ $99 IIRC, the HDS 120 ~ $125, the HDS 170 ~ $159, etc, etc.
    I tended to pick up prior versions secondhand (back when CPFMP was around), at typically ~ 25% - 35% less, after each upgraded release.
    For me, even 100 lumen output is just fine, and I now have an assortment of plenty of older models for not much net cost difference than my Malkoffs.
    That system probably wouldn't work now though, because most of the vintage stock is not trading so commonly.
    I appreciate having both HDS and Malkoffs very much, but use them each in rather different settings.
    ... is the archimedes peak
