HEADLAMP! Custom- SPOT ~1000+ Lumens & additional FLOOD ----0- Ideas,
skygear
Looking to make a custom HEADLAMP.
Will be using a 18650 setup. Willing to use multiple 18650 and or make a remote pack for all night use.
Hoping for true 1000+ Lumens up to 2000 range. Not posed to more. This needs to be a SPOT pattern in WHITE
Maybe a Spot Pattern in RED also.
Need FLOOD in red and White.
Modes need to include
- SPOT full, medium, low
- FLOOD full, medium, low
- RED or WHITE selection mode
Can be multiple switches
Water resistant
Charging over USB-C PD - Maybe programming over it too?
Some ideas I have had are just take apart a couple lights I already own and cobble something together. I have one of the Dewalt SPot Lights with the RED spot too. Could turn that into a headlamp with a remote battery.
Ideas? Builders?
Direction on drivers, chargers, etc.? Help me brainstorm.
skygear
So far, looks like I am building this myself.
Decided on a couple LED options.
CREE XP-L https://www.ledsupply.com/leds/cree-xlamp-xp-l-high-density-led-star
- one single in natural white
- one triple in natural White.
XP-E2
-one triple RED
Cree Custom
- one three up,
---UV 400-410
---UV 410-420
---ROyal Blue XP-E2
Cree Custom
-three up
---XP-L Natural White
---UV 400-410
---XP-E2 RED
LENSeS
Carclo Plain Tight Spot
Carclo Plain Tight Spot 3 Up
Charging
USB-C PD
-ZY12PDN Type-C PD to DC USB Fast Charge Trigger Poller
Looking for drivers now that can run all 3 of the XP-L's Any Recommendations? Thats 3 Amps x 3 = 9 Amps. So maybe 10Amps total driver?
skygear
Something like this?
[h=1]0-10+ Amp capable LED Flashlight driver board 17mm, Cree XHP70, XHP50, XML2, XPL\[/h]https://www.ebay.com/i/201546868150?chn=ps&var=500743716144&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=500743716141_201546868150&targetid=539174380555&device=c&mktype=pla&googleloc=1015197&campaignid=6470648147&mkgroupid=74956728902&rlsatarget=pla-539174380555&abcId=1139336&merchantid=6296724&gclid=CjwKCAjwibzsBRAMEiwA1pHZrutJt3vi815qmJWAMZPdUjRaPS1V9KSIRT_WlRtbOxuEiygloxm5OBoCvSoQAvD_BwE
datiLED
Atlanta, GA
You would be better off finding a headlamp that is close to what you want, and modify it for your purposes. Starting from scratch can get expensive quickly. The key to maintaining high lumens is effective heatsinking.
A high current driver is easy to find. http://www.mtnelectronics.com/index.php?route=product/category&path=67 I like the QLITE driver for simplicity and performance. At 3.04A, it will drive the LEDs past the 1000 lumen mark. A FET deriver will give even more power, but produce more heat.
