Jetbeam
Results 1 to 3 of 3
Thread: Install relays for 99 Toyota Prado
    Unenlightened
    Sep 2019
    Default Install relays for 99 Toyota Prado
    I want to upgrade the headlight harness on my 99 Toyota Prado. Can anyone post the circuit for the negative switching?
    Cheers
    Dan
    Moderator Alaric Darconville's Avatar
    Sep 2001
    Stillwater, America
    Default Re: Install relays for 99 Toyota Prado
    Quote Originally Posted by chadwd View Post
    I moved your post to a new thread because it was an incredible necropost. With the following google search:
    Toyota ground switched relay harness site:candlepowerforums.com
    I see one match is to the post you quoted-- and the image link is broken. Sometimes that just happens. But below his post I'd mentioned would save it locally, so I'll see if I have it somewhere and can post it to my webspace (hopefully it's already up there).
    I believe there's not a whole lot different between setting it up for a ground-switched and source-switched lamp circuit but I could be wrong.
    It's a '99, which means those lamps are 20 to 21 years old depending on when the car was made. It may be time for new (and genuine Toyota) lamps because even the reflectors themselves age, and it's not extremely likely the lenses are good enough to even attempt to polish out.
    Toyotas like this aren't just ground-switched, they also require specially-configured relay harnesses with extra components (diodes, resistors, etc) so that the high/low beam switching and the high-beam telltale on the instrument panel will work right.
