HDS Systems
Results 1 to 13 of 13
Thread: Need help with finding a new single AA EDC
    Oct 2003
    Washington(the state)
    Default Need help with finding a new single AA EDC
    Looking for a single AA pocket light to replace my current Thorfire TG06 EDC. My requirements are:
    Single AA alkaline
    Tailcap clicky
    Single or multi levels of output but must start at highest level
    Highest output mode should be a reasonable level that can be maintained for more than 30 seconds on alkalines
    No Mode memory
    No Electronic switch
    No Side switch
    Thanks.
    S.O.S. - Really? Seriously?!
    Default Re: Need help with finding a new single AA EDC
    Check out the Sofirn SF10. Runs on one AA or a 14500 li-on (if you ever wish to use one). Has a clicky tail switch. Starts in high mode, no memory. Runs at 100 lumens on AA and will last hours. Puts out 50, 15, and 2 with half clicks of the switch. Double tap gives a strobe mode. Going for less than ten bucks on various Chinese sites.
    peter yetman's Avatar
    Mar 2014
    North Norfolk UK
    Maybe have a look at a Streamlight Protac 1L 1AA. As well as running on a single AA it can also use a CR123 for higher output and versatility. 3 different mode groups, 1) high/strobe/low 2) high only 3) low/high.
    Plus it will run on primaries or Li-ion.
    It may be just the ticket.
    P
    Peter's shopping list:- HDS / Oveready 170N Exec/LE and an Oveready V4 Nichia Drop In. Otherwise I'm content. Want want want, that's me.
    +1 on the 1L-1AA - that's what I am carrying. I usually run it on Eneloops but it will work with alkaline AA's and even AAA's if that's all that you have to feed it.
    Quote Originally Posted by longuylander View Post
    Runs at 100 lumens for hours on an AA? Or runs with a slowly (or rapidly) declining output for hours?
    Coast HX5, if you want adjustable focus. Only 1 output level. I ran mine on NiMh rechargeables, so I don't have any idea of runtime on alkalines.
    That's actually a good question, and one I cannot answer. I've only run it on Li-on or NiMH. I'd like to guess that it would hold up well for a couple of hours. They do list the run time on an alkaline AA as 8 hours total on high... If that's true, it'd have to be because of diminishing output.
    Oct 2003
    Cant really find any good revues on it but it looks pretty close to what I'm looking for. Unfortunately its unavailable on Amazon and I'm not too crazy about purchasing from a foreign website-credit card, personal data etc.
    Oct 2003
    Looking into the HX5 and PROTAC. both lights are pretty big...
    Oct 2003
    Gawd Amazon can be infuriating sometimes.
    Search for "sofirn sf10" and you get 2 results for the SP31 and C8F. Search for "sf10" and you get 804 results for water filters, books, tennis shoes, hoses, chairs etc. but the very first of those 804 is for a sofirn sf10 selling for $8.99.
    Anyways, I have one coming tomorrow. Time to go to bed
    Mar 2014
    North Norfolk UK
    That's funny, I've just ordered the Protac.
    Should be here in 10 days or so.
    P
    And if you search "sf10 sofirn" it's the only light that comes up! How can a company like Amazon have such a flawed search engine?
    Regardless, I hope you like the light when it comes!
    Oct 2003
    Okay, received the SF10 and initial impressions are positive. Build quality is surprisingly good for a 9 dollar light and it works flawlessly out of the box.
    Its a lot bigger than I was expecting. Diameter approximately the same as the Thorfire TG06 and slightly longer by maybe 1/16. The old Fenix E11 is still my gold standard.
    High mode is visibly lower than the Thorfire which matches up with the advertised specs of both lights. Going to put fresh alkalines in both lights and run both on high and see how the SF10 holds up. Hopefully it can hold the high mode for at least for several minutes before stepping down to next level.
