finitetime
- Joined
- Apr 17, 2019
- Messages
- 6
Hi guys. Great forum. Based on what I read on here I purchased a the maha c9000 a few years ago and some eneloop batteries. Both have been well worth it thanks.
I have some 5 month old White Amazon basics that are rated at 750mah. FYI box said they were from China not Japan so they are probably not rebranded eneloops. I charged them and realized I got low mah out of them so after using them for the day in my head lamp I preformed a refresh and analyse with my maha c9000. One came out 405mah the other two were in the high 400's. I don't have a lot of experience with this charger and have a few questions. I had one more
What should I do next? From what the manual says I should preform one or two more refesh and analyze. What should the Charge and discharge rates be for this? My first time I charged at 200 (my normal charge rate and discharged at 100. I assumed that slower discharge would be better but I could be wrong. If refresh doesn't work what then?
When should I use the cycle feature?
