akula88
When I started out with Pila LiIons decade and a half ago, I was made to understand that using protective circuit on mod'd light was the best way to go. Also got to do with the Pila charger which had no detection on voltage readings.
LiIon technology and chemistry had advanced thru the years. Is it still necessary to use protection circuit on most lights?
I acquired a couple of Surefires and had them bored for 18650 :
- U2 with emitter mod'd with XP-L HI.
- stock P2x Fury.
I would like to use unprotected 18650s on them, essentially due to their lesser diameter over those with protection circuit-added.
I'm currently experimenting a Samsung 30Q (button top), but had to removed the add-on (thick) transparent wrap.
- stock P2x Fury.
