I prefer a... light around 5000 K
tint deviation is not relevant to your goal of buying a 5000k light. Buy the color temperature you want.
whether the 5000k will look green or blue to you, depends on whether your brain is adapted to sunlight, or incandescent.
a 5000k light will definitely look blue (cooler) compared to incandescent (3200k), but it will not look blue compared to sunlight (5700k).
green tint from the 5000k will be very obvious, compared to incandescent (3200k), but it will not look as green compared to sunlight (5700k).
As Twistederaven explained so well, Sunlight has more green in it than incandescent
Midday sunlight is slightly green
Our Brain's perception of flashlight Color, and Tint, changes, based on the ambient light our brain is adapted to, at the time when we turn on the flashlight. It takes our brain 30 minutes to change its White Balance in relation to the ambient light.
Therefore, If Im in the sun, and then go into a dark space and turn on a 5000k light, it will look closer to "white", without blue color.
Otoh, If I have been indoors at night under incandescent, and I go into a dark space and turn on a 5000k light, it will look blue. It will also show the green tint more, than it did when sunlight adapted.
