idleprocess
Looking for a simple-to-operate LED flashlight to give as Christmas gifts. Target audience is effectively grandparents who need a flashlight to put in a junk drawer, glove box, purse, or toolbox for extremely occasional use - but it needs to work when called upon; as such electronic switches out out (unless someone has finally perfected zero standby current). Single-switch UI is fine so long as the mode sequence makes sense. Program-ability is not wanted. Compactness is important, however 1xAA will more than suffice - no need to go with 1xAAA or some USB-charged lipo-powered light likely to self-discharge within 3-6 months nor something that runs on coin cells and has a runtime of 10 minutes. Lithium AA compatibility is important - I've sworn off trying to salvage alkaline leaks and these users will not suffer NiMH cell maintenance thus they'll be handed a stack of Energizer lithium AAs with these.
The laundry list:
Going over Parametrek's entries, the following look to be moderately compatible...
The laundry list:
Ultratac A1 honestly looks to be the favorite from the list, however I've not kept up on this specific niche thus there might be options I'm missing.
EDIT: The Lumintop Tool AA should probably also be on the list.
Appreciate any advice the community has to offer.
The laundry list:
- ≤$50 price point
- Conventional cylindrical formfactor in aluminum or any other reasonable metal
- Replaceable 1xAA : 1.5V Lithium, alkaline, NiMH
- Simple operation w/ no SOS, party strobe, whatnot
- Flood beam for tasks
- High output is not a priority
The laundry list:
- JetBeam SF-AA01 - Upsides: Inexpensive, single tail switch, seemingly a forward clicky. Downsides: SMO reflector for throw, can't locate a user manual to describe operation, first review I came across doesn't care for the UI/switch.
- Fenix LD09 - Upsides: I've had good experiences with Fenix, forward clicky switch might be more intuitive for inexperienced users toggling modes than reverse. Downsides: SOS mode, pricier at ~$40
- Streamlight Protac EMS - Upsides: Brand reputation, apparent forward clicky. Downsides: "High" output is a tad low.
- Pelican 2350 - Upsides: Brand reputation. Downsides: Dumb default mode sequence means I'll have to reprogram it and hope that said program is stored in some sort of nonvolatile memory and also isn't accidentally changed.
- Ultratac A1 - Upsides: Inexpensive, OP reflector for a diffuse beam, includes a diffuser, no strobe/SOS, available in neutral tint on Amazon. Downsides: I'm not so sure on the brand.
