Imalent has released a new flashlight LD10 which is thumb-sized and versatile:twothumbs:
LD10 is a thumb-sized USB magnetically charged multi-functional EDC keychain flashlight with awsome output up to 1200lumens. The OLED display on the tail cap make it easy to control the flashlight status. With the high quality diffuser, LD10 can be a cute camping light. LD10's small size, light weight, high intensity beam and high output make it a perfect keychain flashlight for outdoor, walking, climbing, camping and repairing work light.
·Utilizes 1 piece CREE XPL HI LED,with a lifespan up to50000 hours,and a maximum output up to 1200lumens.
.5Output levels from10lumens to 1200lumens ,meet your needs in different circumstances
·Built-in multi-functional OLED display, which can show various parameters and settings
·Size:72mm(length)x22.5mm(diameter)
·Net Weight:50g/100g(battery included)
·High efficiency constant current circuit will maintain constant brightness
·Built- in thermal control module will automatically adjust the brightness output,keep using comfortably.
·Combination of toughened ultra-clear mineral and anti-reflective coating glass
·Aluminum OP reflector
·Aerospace-grade aluminum alloy body, wear-resistant type III hard- anodized surface treatment.
·IPX-8 standard waterproof(Under water 2meters)IMALENT Official store:www.imalentstore.com
