New Product Announcement: NITECORE HC35 2700 Lumen L-Shape Headlamp
NitecoreStore
Texas
NITECORE HC35 2700 Lumen L-Shape USB Rechargeable 21700 Headlamp
2700 max lumen quad CREE XP-G2 S3 LED headlamp
Included 21700 high performance 4000mAh rechargeable battery
Built-in micro USB charging port (cable included)
L-shaped body with magnetic tailcap and included pocket clip
Now taking pre-orders! Use coupon code CPF15OFF to save 15%
SKV89
Just received mine from Illumn.com and charged up the included battery. The build quality is great and feels good in the hand. It has a unibody design where the head and battery tube is one piece, which allows the entire flashlight body to be used for heat dissipation, which is an excellent design IMO. Also the deep fins in the back of the head are excellent for head shedding. Light looks great too.
However, I don't like the UI. Click to turn on, click to change modes, and click and hold to turn off. If I knew the UI was like this, I would not have bought the light. The single button UI on the Olights, Thrunites, and Acebeams are so much more intuitive and simple. Also I'm surprised Nitecore used Micro USB instead of the much preferred USB-C given how new this light is. Nitecore should offer a 4000K version since head lamps are much more useful and easier on the eyes at warmer temperatures. I'm disappointed in all the manufacturers offering CW only. Even Olight is starting to offer NW emitters like in the popular M2R Pro and Warrior X Pro.
Output measurements taken at 2s after turn-on using Texas Ace Lumen Tube calibrated with Maukka lights. Spectrometer used is the Sekonic C-800-U
Nitecore HC35Mode 52,612 lumens8271K-0.0088 DUV71.5 CRI4.7 R945.3 R1262 Rf99 Rgincluded battery
Nitecore HC36Mode 4789 lumens7356K-0.0036 DUV72.3 CRI-7.6 R942.5 R1266 Rf97 Rgincluded battery
Nitecore HC37Mode 3253 lumens7081K-0.0010 DUV73.1 CRI-11.6 R941.3 R1268 Rf96 Rgincluded battery
Nitecore HC38Mode 237 lumens6836K0.0010 DUV73.4 CRIincluded battery
Nitecore HC39Mode 12 lumens6541K0.0022 DUV74.1 CRIincluded battery
