Mateminco MT07vn - Compact High Output Thrower R
Skylumen
  • White 2 5400K
  • Max Turn On Perf: 7700L, 115Kcd, 678m
  • Unbelievable Performance!
  • Must Have!
  • Email for other LED Options
  • $135 Aluminum any body color
  • $175 Brass
  • $200 Copper
Skylumen
32% more Lumen and 100% more intensity compared to E07vn W2!!!!!!!!!!!!!!!!!!!!!!!!!!!!
twistedraven
usb-c charging retained?
How does White 1 compare? How does a 30t compare to a high drain 26650?
I knew this would be a banger!
Skylumen
Still trying out more LEDs. This light is AMAZING! Please give me some time ;-)
Patriot
Arizona
Is this an OTF lumen record for a single cell and if that's the case, holy cow... what's the XPL going to do?!
Super interested in the throw numbers for W1/W1.1!
Can the lens be removed from this too like the D4Svn for a supercharged throw ability? If this could get 150kcd and 5k Lumens from W1/1.1, even if a supercharge lens removal is required, I am sold.
Patriot
Arizona
5000L is certainly within reach, as the E07 is pretty much there now! 140-150kcd also seems like it could be possible based on the increased throw between W2 & W1 in the E07... but I realize this can all depend on how the W1 fits the optic. I know sometimes it doesn't work out the same for both LEDs.
This is really an exciting light!
Agpp
I wonder what is the reason for such lumen difference against E07?
Both are FET based and I assumed E07 already had low electrical resistance all around.
Optically both have TIR + AR coated glass lenses.
Unless there was something wrong (and condsidering we're comparing Vn lights - not easy to correct) with E07 they should produce very similar output...
Patriot
Arizona
Is this light using a broadband, multi-coat lens and if not, is there a lens deletion option. If no delete option, is there a UCL replacement? I could look it up myself, I just don't know the size.
twistedraven
UCL lens could add like 5% output and have better tint.
Any word on White1 performance?
twistedraven
Damn. So are the optics in this light larger than the MF01S? Is White2 not being an option in that light just an issue of too much hassle to center 18 leds? And are these White2s really 5400k? I remember you initially said they looked like the same 6500k W2s from earlier.
Skylumen
Damn. So are the optics in this light larger than the MF01S? No much smaller. 7 LED Vs 18 LED.
Is White2 not being an option in that light just an issue of too much hassle to center 18 leds? The LED footprints is different enough that W2s will not sit right.
And are these White2s really 5400k? supplier say its 5400K. To my eyes 5500-6000K
twistedraven
No I meant the size of each individual optic. Like is the diameter of each optic larger leading to more throw per led or same size?
