Hi,Dear Imalent fans,
Thanks for your longtime support.Now we have released a new tactical flashlight DM21C.:twothumbs
The IMALENT DM21C is a versatile tactical LED flashlight,powerd by single 18650 3000mha, capable of multi-level output. Thanks to its dual mode - 5 output mode and infinite brightness adjustment mode - this flashlight is ideal for search and rescue, law enforcement, and other tactical applications!
.·Utilizes one CREE XHP 35 HI LED. The lifespan up to 50000 hours with maximum output of 2000 lumens.
·Built-in multi-functional OLED display shows the battery voltage, output, charging status
·USB magnetically charging function make it easy to get power.
·Product size: 122mm(length)*26mm(diameter)
·5output levels from20lumen to 2000lumens,and steppless dimming mode from200lumen to 2000lumens
·High efficiency constant current circuit will maintain constant brightness.
Built-in thermal control module will automatically adjust the brightness output according to the working state and outer temperature
·IPX-8 standard waterproof (2 meters submersible)
IMALENT Official store:www.imalentstore.com
