MecArmy
- Joined
- Aug 25, 2016
- Messages
- 16
The PS16 is equipped with 4 CREE XP-G3 S5 LEDs, the lifespan up to 50000 hours. 3 lighting modes and 1 Strobe special mode, max output up to 2000 lumens and max run time up to 60 hours. It can be powered by 16340 or 18350 Li-ion rechargeable battery. Made of Stainless steel/Copper/Titanium, smooth metal reflector. Temperature protection prevents overheating and heat dissipation grooves. Anti-roll with excellent grip, tail stand capability and trident tail section for emergency self-defense.
What's in the package:
- MecArmy PS16
- USB rechargeable 16340 battery
- USB charging cable
- Lanyard
- Stainless steel pocket clip
- Spare O-rings
Operation:
- From OFF: Fully depress switch for constant-ON
- From ON: Fully depress switch for OFF
- From OFF: Lightly depress switch to activate momentary-ON, lighty depress switch again to change modes cycle through (Med/ Low/ High/ Strobe), release for OFF or Fully depress switch for constant-ON
- From ON: Fully depress switch to turn OFF, fully depress again for change models cycle (Med/ Low/ High/ Strobe)
- Memory function: The brightness level will be memorized if left ON for more than 5 seconds. The device will return to this mode when next turned on.
Charging:
- Unscrew the tail cap and take out the battery then connect a cable to charge.
- Input: Micro USB, 5V/0.4A
- Charging time: 2.4 hours (16340 650mAh)
- Charging indicator: Located at positive polarity, Red is charging, Green is fully Charged
Dimensions:
- Length: 85.25mm/3.24in
- Head diameter: 29mm/1.14in
- Body diameter: 23mm/0.91in
Weight:
Empty: 122g/4.303oz (Stainless steel)
122g/4.303oz (Cooper)
94.7g/3.34oz (Titanium)
With battery: 155g/5.467 (Stainless steel)
155g/5.467 (Cooper)
128g/4.515 (Titanium)
Output & Runtime:
Mode/ Specification | High | Med | Low | Strobe |
Output (Lumens)/ 1x18350 IMR | 2000~600 | 520~400 | 20 | 2000 |
Runtime/ 1x18350 IMR | 0.5mins+1.3h | 3mins+3h | 6h | / |
Output (Lumens)/ 1x16340 | 1500~600 | 520~400 | 20 | 1500 |
Runtime/ 1x16340 | 0.5mins+45mins | 3mins+1.8h | 33h | / |
Peak beam intensity | 5376cd | |||
Max beam distance | 146m | |||
Impact resistance | 1.5m | |||
Waterproof | IPX7 |
Warranty service:
- Guaranteed exchange up to 15 days after purchase: any defective product can be exchanged for a replacement through a local distributor/dealer within 15 days.
- After 15 days: all defective products can be repaired free of charge for a period of 2 years from the date of purchase.
- Lifetime workmanship guarantee: after the free maintenance period has expired,the maintenance service will charge for material expenses only, free of labor expenses.
http://mecarmy.com/search/index/61
https://shopmecarmy.com/search?q=PS16
