HDS Systems
Results 1 to 1 of 1
Thread: MecArmy PT16 Ultra Bright USB Rechargeable Compact Flashlight 1000 lumens
    Default MecArmy PT16 Ultra Bright USB Rechargeable Compact Flashlight 1000 lumens
    *Uses 3 CREE XP-G2 LEDs, lifespan up to 50,000 hours
    *Momentary ON function
    *Uses rechargeable 16340 Li-ion battery (brightness and efficiency will be lower with CR123A battery), compatible for 18350 battery
    *Quick recharge, Standard Micro USB Charging port, charges on any USB port
    *Charging and fully charged indicators
    *Electronic side switch design, easy to change modes
    *Wide voltage range circuit design
    *Over-heat protection to avoid high-temperature of the surface
    *Reverse polarity protection prevents damage from an incorrectly inserted battery
    *Rugged pineapple texture for grip and anti-roll
    *Constructed from aero grade aluminum alloy, with HAIII hard-anodized
    *Tail stand capability
    Mode/ Specification
    Turbo
    Low
    Med
    High
    Strobe
    SOS
    Output (Lumens)
    1000
    5
    100
    420
    1000
    1000
    Runtime
    35mins
    20h
    4h
    1h
    Peak beam intensity
    4915cd
    Max beam distance
    140m
    Impact resistance
    1.5m
    Waterproof
    IPX8 (underwater 2 meters)
    Length:67.5mm/2.66in
    Head dimension:30mm/1.18in
    Body dimension:22.5mm/0.89in
    Weight:40g/1.41oz (Excluding battery)
    Working voltage:2.5V-8.4V
    Charging time: 90 minutes (charging current 600mA)
    Accessory:User manual, 1×16340 Battery, O-ring, lanyard
    https://shopmecarmy.com/search?q=PT16
