I do a lot of night driving (I am on the road all day starting at 4 AM), and I would like to upgrade my headlights in a safe and proper way, especially since I have already hit 2 deer this year.
If a/the headlamp(s) was replaced after a collision, make sure it/they was/were replaced with a genuine factory part, and that the aim is correct.
As far as deer avoidance, your early-morning drives, particularly from October through December, mean you're going to need to be alert, scanning the road constantly, using your high beams whenever possible, and
*slowing down*. Also, by now you probably also know that if you see one deer crossing the road there are probably others crossing with it.
Also, if your Cruze has fog lamps, don't use them inappropriately. They aren't ever going to be useful in clear weather, nor are they useful at highway speeds-- in fact, they make things worse in those conditions.
The design of the Cruze doesn't lend itself to installing traditional auxiliary high beams, but Hella have a light bar, made by JW Speaker, the
Hella 958040071 350, in the driving beam pattern.
