So it's a reference 12.5 high beam, officially. No mention of work light, just "for multi-application" on the clear-lens Valeo 046152. (Maybe re-merge threads?)
Found a German (online) street price under 70 EUR excl. VAT, free returns, so I checked one out.
Item's (Valeo 046152) description on packaging is:
CIBIÉ MyBEAM Cube
LED HIGH BEAM - 3.2" 81 mm
Extra Vision 1,050 ft / 320 m
High Intensity 60,000 cd
White Color 6,000 K
FOR PROFESSIONALS [printed black on yellow]
Homologation ECE-SAE-CCC
12/24 V / 17 W
[This also in ALL-CAPS:]
resistant to extreme conditions
protection IP67 certified
vibration up to 10G
corrosion and UV resistant
no electro-magnetic interferences
for Multi-application
Made in China
Exterior packaging dimensions measured:
185w X 105h X 119d mm
lamp mass including washers, nut, 45 cm wiring with 2-pin connector: below 500 grams
plastic front lens
front part (also metal) attached by four 2 mm allen key screws.
LENS MARKINGS:
SAE Y14 CCC A061715
01 HR PL
E4 12.5 0468
wires protruding from the back, meaning that a few extra mm's are needed if bending (and some extra shrinkwrap) is required
multi-lingual (EN/FR/ES/DE/IT/RU/PL) info leaflet, meaning: sub-millimeter print size
one membrane-covered vent hole on the back, near the top
one M8 fixing bolt, nut, washers, steel, hot-dip zinc galvanized
two M6 vertical adjustment screws, 8.8 steel
100+ degree angle adjustment bracket's mounting base is 5w X 2d cm, 2 mm thick magnetic, painted. Slotted mounting hole is 2 cm long (l-r)
Attention tint modders (for show cars, and Alaric's bus parties, only):
two domed LEDs, probably Cree XPL HD, positioned side-by-side, apparently on a rectangular MCPCB that is screwed onto an alu (not zinc, hopefully) die-cast plate (or that's the inside of the lamp housing).
two white wires visible, might indicate parallel connection of LEDs.
maximum focal length: about 6 cm estimated
Vertically mounted, green pcb of the driver visible through slot in the reflecting chamber.
