New Product Announcement: NITECORE i4000R 4400 Lumen Flashlight
NitecoreStore
Texas
NITECORE i4000R 4400 Lumen USB-C Rechargeable LED Flashlight
4x CREE XP-L2 V6 LEDs for a max output of 4400 lumens
Included high performance >15A 5000mAh Li-ion battery​
USB-C rechargeable (cable included)​
Dual tail switch - one touch 4400 lumen strobe
Now taking pre-orders! Use coupon code CPF15OFF to save 15%
lightfooted
So is the AIRPPM the final realization that you need to put a spring on BOTH ends of the battery tube? About time. It would have been nice to see a 700-800 lumen medium 2 mode as well, but at least it doesn't just go from 330 to full blast 4000 lumens. A semi-turbo would also have been nice but mostly just because I like to have options. 2000-3000 lumen Hi 2 or whatever.
NitecoreStore
Texas
So it comes with a dedicated battery. Does it also run on a regular (already charged) 21700?
No, the i4000R requires the i Series battery it comes with to operate. This special battery has positive and negative contacts on one end which is why a normal 21700 will not work.
