LED-FX
Had an unfunny experience in my car yesterday, 1.5 diesel Citroen.
Doing just over 70mph in outside lane of dual carriageway, back off throttle approaching car in front, throttle dosen`t react, just keeps revving.
At first lent on brakes but figured engine pulling against brakes would cook them and leave me hurtling with no brakes.
So put clutch in, still in outside lane at time, strain on engine as it revs out blows head gasket, think, pours oil on to hot exhaust big clouds of smoke, must have looked good to spectators, car doing just under 70 veering across road with engine reving out and smoke belching from bonnet
As it begins to slow , head for hard shoulder and switch off ignition, nothing happens, engine continues to rev...
Electric strangle valve appears to have failed as well?
Getting below 20mph on hard shoulder managed to stall thing against brakes eventually.
Fire service turned up ptretty quickly but luckily car didn`t reach ignition point.
Haven`t torn into it totally yet to find failure, but intial check dosen`t show any jammed throttle cable, wondering if its a failure with the nechanical injection pump, anyone heard of similar incident?
Also wondering why wouldn`t shut down from ignition key, one suggestion was that blown cylinder head gasket meant hot lube oil spraying into bores and acting as fuel.
The car is going to scrap as the engine is demolished and frankl;y would`nt trust the thing again, but just looking for any suggestions as to cause.
Thanks
Adam
Thanks
Adam
