Coronavirus flashlight
conandrum
Hi all, first post here.
In need your help...
to create a UVC LED flashlight for disinfection purposes eg. bacterial, viral etc.
I found this UVC 4xLED:
https://www.aliexpress.com/item/400...earchweb0_0,searchweb201602_,searchweb201603_
I want to use the above PCB and make my own flashlight, by either:
  1. Buy a host and relevant accessories or
  2. Buy a ready-made flashlight and swap the PCB
From the information on the page I can see:
  1. LEDs cover a 7.5x7.5 mm area which should be considered
  2. PCB is a 20x20mm area which should be considered
  3. 2x 18650 should be enough based on voltage requirements.
I have not done a flashlight from scratch before (just upgraded my maglight to 3xLEDs).
I need some guidance from the experts in here.
Thank you in advance
conandrum
Are you going to name your flashlight Coronavirus? How does your post relate to a sickness? Cleaning surfaces will not guarantee contracting this disease, right?
I am not interested in selling or naming the flashlight. I just want to make some for my family and friends asap. Plus it may be useful for everyone else.
nbp
Wisconsin
You can do some searches with the Google bar at the top regarding disinfecting with a flashlight. It has been brought up a number of times. But as I recall it's unlikely you can generate enough power to make such a thing effective.
conandrum
Thanks for the tip - I will have a look.
As to the effectiveness, you could also try a search for medical studies. Some have shown that 2500uJ/cm2 can easily destroy any living microbe in under 15s from a distance of 2-3 cm.
So I am sure it will be effective the closer you get it and the longer you have it running.
No worries.
Also bear in mind that there already exist commercial UVC LED offerings out there, but most are gimmicks with just 1 LED for more than $30! The serious offerings are over $100 and they are all quite effective at a 2-3cm distance with the only difference being the time it takes to neutralize the hazard.
What I really need is some pointers towards either a source for host flashlights which can take this 20mm pcb and can take 2x 18650 or other appropriate battery.
I have already contacted xtremegadget.com mtnelectronics.com fasttech.com flashaholics.co.uk but they could not provide any help in fitting this pcb into an appropriate host.
I need the help of an experience builder who can look at the PCB and suggest to me an appropriate host based on his experience of what hosts he has seen out there.
I can easily take it from there.
RCS1300
Stamford, CT
The UV wavelengths needed to disinfect are typically not available to the public. You will not find these emitters online.
UV-C wavelength of between 200 and 300 nm kills or inactivates micro organisms by destroying their nucleic acids and disrupting their DNA. Whether this will be effective against a particular virus would have to be tested. (If it were effective against this new virus you would have seen or heard about it already).
I will see if I can find you an article that describes the different wavelengths and their purposes.
Edit add:
https://materion.com/resource-cente...-news-stats-and-chats/killing-germs-with-leds
"In particular, the wavelength of 264 nm is incredibly impressive at killing germs, viruses and bacteria."
conandrum
Oh, before I forget, the MAJOR reason I want this thing is for MASK DISINFECTION.
Masks are very expensive. We cannot be throwing them away after a few minutes of wearing them.
With this flashlight we could just pass it over the outer surface of the mask and it will be safe to use again for at least a few more times.
In my opinion it is well worth it for the money you will be saving.
Of course you could buy one of those portable UVC lamps, but you cannot beat the portability of a flashlight, plus it is better for those who hate ozone.
conandrum
The 275nm is PERFECT and the PCB I posted is 275nm. I am well aware of all the UVC capabilities already in the public domain.
nbp
Wisconsin
UV-C wavelength of between 200 and 300 nm kills or inactivates micro organisms by destroying their nucleic acids and disrupting their DNA. Viruses do not have DNA as a virus is not a biological. I do not believe a UV-C light will work against a virus.
Viruses are actually DNA strands wrapped in a protein coat so UV can destroy them but whether a flashlight can offer sufficient destructive power I am not sure. When I worked in the lab for a contract packager years ago our RO water system had UV capabilities but the water ran past multiple large UV lamps wired into the system. I don't know the specs but they were pretty powerful. Personally, I suspect use of a proven cold sterilant would be a cheaper and more effective way to disinfect hard surfaces. It is not however, a more FUN way to disinfect. :)
RCS1300
Stamford, CT
Thank you for that.
https://sciencing.com/virus-dna-4058.html
The OP is not going to get his hands on a LED emitter that will have the proper wavelength. If he could, it would have to be exhaustively tested against the particular targeted virus. Duration and intensity of exposure would be variables tested.
conandrum
I will agree with you on the fun part for sure! I love building stuff myself.
But please keep in mind that UVC lamps in water filtration systems have a very small window of time to kill whatever passes in their vicinity.
This build is different. We have ample time to disinfect small items.
Most manufacturers have 90s timers built into similar offerings.
If in doubt, go over your item for 2 minutes at close distance. That should do it.
conandrum
Guys, 275nm kills everything. All you need is 2500uJ/cm2 for 15s. I have done enough research to be confident in this.
Therefore 2500uJ/cm2 for 90s from 2-3 cm is more than enough to kill anything inside the pores of your mask for example.
275nm is very pervasive - it will even penetrate your skin and even give you skin cancer. Very dangerous stuff. It will work.
conandrum
I cannot provide a link guys (as per CPF policy), but you could do a search for a company called 59s and have a look at their products.
You will see the LEDs we are talking about.
e.g. they have a wand product with 20 LEDs and some sterilizing containers.
All I want is a host for this 20mm pcb which can supply 6+ volts and a controller which has only on/off.
That's it! Please give me some directions.
nbp
Wisconsin
I'm not that good at building lights so I cannot offer a lot there but my background is in biology and working in a lab where we made OTC drug products for skin care so the nerdy science part of this is fun for me and that's the angle I am trying to help with here.
In any case, whatever you do end up building, it is critical that you send it out to an accredited lab with microbiological testing capabilities to have the device fully validated before you use it to sterilize medical devices of any kind. Otherwise it may be as effective as a spoon is at sterilizing and you won't know it, leaving you in the most dangerous possible situation: believing something is safe when it is not. Much of the cost of the commercially built solutions will be the cost of properly validating the device in labs to do exactly what it says it does given a particular usage case. Since your device will be home built, you will need to have this done to be certain it works in the way in which you intend to use it. Then and only then should you trust it with your safety!
conandrum
You are absolutely right. Nothing worse than a false sense of security.
Safety should be the top priority here.
archimedes
CONUS, top left
For a variety of reasons, what you are describing is unlikely to be effective and/or safe.
Without getting into the weeds of the discussion, I agree with @nbp that for your stated intended purpose(s) a "home-made" hobbyist-type project would be inappropriate.
conandrum
You may be right there.
Of course, even the commercial products mentioned earlier, could suddenly decide to malfunction, thus leaving you with a 'false sense of security' as NBP already mentioned.
Even so, that does not mean that we have to give up.
I myself also do not want to get into a deep discussion into medical and health safety issues, but I will provide the following points for you to consider.
1. In case of a pandemic, when you are having difficulty obtaining masks (plus costing an arm & leg), you will be forced to disinfect what you have. I will remind you that recently we were shipping masks to China because they run out! Can you believe this?
2. It is better to have a solution rather than none at all.
3. You should not have only one solution. Always have a backup. Masks are built to BLOCK most everything. So how do you disinfect the pores? Ozone could be a second option, but it has to travel into each pore. I am not certain it can be done. Radiation will most certainly do the trick. (using liquids probably will not work and actually may help to either deform, moisten or block the mask, lowering its effectiveness or even rendering it useless - in an emergency you could run alcohol through it, but that is just wasteful IMHO)
Keep this in mind.
UPDATE:
Yes, for most consumer masks like N95, N99, P100, FFP3 etc, ozone will have no problem penetrating and passing through it. This is because 'MOST' of these masks have no active filtering for ozone and other gases (usually requires activated carbon to absorb these). Even a HEPA filter or other type of mechanical filter will have no effect on ozone levels—this includes the filter that might be built into your HVAC system. Therefore, yes, you can use ozone as a secondary layer of disinfection of you masks, keys, shoes, wallets, money.... you get the point.
So come on builders - help me build this thing!
nbp
Wisconsin
What kind of masks are we actually talking about? If they are plastic full face shields then this is easy, cold sterilants will definitely be the way to go. Disposable surgical masks are porous and absorbant and not ever meant to be reused. Furthermore their ability to effectively block tiny viruses is debated anyways. To penetrate the fibers enough to denature microbes buried deep inside I think you will need a powerful light source and a considerable exposure time. In this case I still think submerging them in an FDA approved disinfectant solution and air drying and storing them in a sterilized environment would be the easiest and cheapest and probably most effective way to go.
Then use your soldering skillz to build some sweet flashlights with long runtimes to keep you rocking through the power shortage parts of the virapocalypse!!!
conandrum
LOL :twothumbs you cracked me up!!
Hey guys, let's not get wrapped up in the usecases here. You could sterilize anything... money, wallets, keys, etc. you can have in in your car, back pocket, purse.
Come on, suggest to me a suitable host for this 20mm PCB and a suitable controller and let the build begin. ))
conandrum
Can anyone suggest a suitable host for 6+V that can take a 20mm PCB?
Thanks.
