Klarus
Results 1 to 8 of 8
Thread: McClickey switch
    Default McClickey switch
    What's the trick or mod for stiffening the switch? Can someone explain please and thank you.
    Sent from my LM-V350 using Tapatalk
    wicky998's Avatar
    Dec 2019
    Mardi Gras City
    Default Re: McClickey switch
    I thought it was just the boot to change that was stiffer .
    I could be wrong
    Sent from my iPhone using Tapatalk
    ..Isaiah 54:17...
    I was under the impression that a o-ring is installed. I've been doing some research and found a few articles stating this.
    wicky998's Avatar
    Dec 2019
    Mardi Gras City
    Can you source the link ?
    The only oring I know of is under the boot around the button . Which is what I thought was to seal the boot
    ..Isaiah 54:17...
    I'll try to pull it up. I went down the rabbit hole in Google. It was a article that mention placing a o-ring somewhere. And I also believe in the same article the author stated that the only way to remove a MALKOFF drop in out of the head was by destroying it.
    wicky998's Avatar
    Dec 2019
    Mardi Gras City
    Quote Originally Posted by Fish 14 View Post
    ..Isaiah 54:17...
    I think it's the same mod as the Fw3a. Replacing the oring with a larger heavier one. (thickness not diameter)
    Sent from my SM-N910T using Tapatalk
    Gotcha, now that I think about it, the article was about the fw switch. I gotta lay off the whiskey.Thanks, I'll see if it works
