NITECORE INTELLIGENT 21700 BATTERY SYSTEM - MPB21 KIT: Lantern, Powerbank, Charger
NitecoreStore
Texas
MPB21 KIT with Lantern, Powerbank, Charger
Intelligent power system for NL2150HPi
ML21 80 lumen ML21 magnetic high CRI light​
MPB21 magnetic dual function power module​
MPB21 can charge the battery or acts as a powerbank
Now taking pre-orders! Use coupon code CPF15OFF to save 15%
Tomaao
Wow, 21700 5000mAh! What's the charging current for the mpb21 power bank?
NitecoreStore
Texas
Hey Tomaao, the charging information is on the last image on our post!
The max input voltage that would charge the battery is 5V-2A
and the max output coming out of the MPB21 that you can use to charge other devices is 5V-2A (although this also dependent on your USB cable).
mhsvz39
Coupon code works, thank you.
NitecoreStore
Texas
Hello SKV89, I emailed our production/manufacturers and they gave me a rather vague response. Judging by the brightness and style I would presume it is similar to our NITECORE LR10 lantern which is very similar. That one uses a CREE XP-G3
Agpp
Very nice. Now please add a good flashlight head to the mix....and add some insulation on the negative pole :)
