New battery, top is totally uneven. Should I return it?
berfles
I just got there battery today and the top of it isn't even close to being straight.
​Is that going to be an issue? Actually, looking at the pictures full size it appears maybe just the casing is pulled up higher on one side?
peter yetman
North Norfolk UK
I don't think it's a problem. I'm trying to find you a picture, but for now...
Inside the shrink wrap is a canister which is the cell, the button is placed on the positive end of the cell and a plastic washer is put over the top of the button to keep it insulated from the canister. Then the whole thing is shrink wrapped.
In your case, I think the plastic washer wasn't pressed down enough before the wrapping. If it works don't fret. If it bothers you, send it back or buy some shrink wrap tube (always good for repairing torn wrappers anyway) and rewrap it. You can find it on Amazon under 18650 shrink wrap, I think.
P
Here's a pic....
The picture is a link to the original thread, have a look, you'll never want to use an Untrafire cell - ever.
P
lightfooted
It looks fine to me and if it were mine I would go ahead and use it. The only issue I could see possible is that it may not sit properly in some manufacturers reverse polarity protection designs...like that of Eagtac. That's only a maybe though and would just be caused by the wrapper and washer not allowing the electrode to contact the cell button because it's in the way.
DayofReckoning
USA
Mmm, strange, haven't seen that one before. The cell will likely be just fine, but personally, I would return it for another, simply for the piece of mind.
kpatz
Looks like it's just the shrink wrap that is uneven? That should be fine.
Assuming the cell fits, and works fine, use it.
