Zoomable S2R
m38652
Looking for a replacement for my Olight S2R baton. The main reason is to find a zoomable model. Before getting the S2R I carried a Sipik sk68 which work well for me but wasn't what anyone would call a high quality light. In my work having the ability to have a flood beam that can be pulled down to a spot with every little to no splash is a real plus. I usually use either 18650 or 14500 batteries. Most of the lights I've looked at that fit my needs have been to large to use comfortably for EDC. The perfect light for me would be a S1R or S2R that could zoom.
Any advice would be greatly appreciated.
____I would like to purchase the light in person from a brick and mortar store. I am located in ______________.
__x__This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest! :)
____I don't know yet
____Up to $25.
____Up to $50.
__x__Up to $100.
____Up to $200.
____Up to $300.
____Essentially unlimited.
3) Format:
____I am not sure, please help me decide.
__x__I want a flashlight (hand held/self contained).
____I want a self-contained headlamp.
____I want a headlamp with an external pack/power source.
____I want a mounted light (typically for a bicycle or vehicle)
____I want a lantern/area light.
____I want a portable spotlight (it may have an external power source).
____Other ____________________________________________
4) Size:
____MICRO - Keychain size.
__x__TINY - Every day carry (2-4 inches).
__x__SMALL - Every day carry (4-7 inches).
____MEDIUM - Holster/belt ring carry. (>7 inches)
____LARGE - Big enough to need its own travel case.
____I don't know/I don't care.
5) Emitter/Light source:
__x__LED (known for efficiency, longevity, and compactness)
____I don't know.
6) Manufacturer:
__x__I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
____I would like a light from a specialty manufacturer (Possibly limited run/Custom).
____I am interested in assembling my own components. (for example a "host" or flashlight body from one manufacturer, and a "drop-in" emitter from another source).
____I intend to use "Primary"/Disposable Alkaline batteries based on the usual AAA/AA/C/D sized cells common to most stores.
____I intend to use "Primary"/Disposable Lithium batteries based on the usual AAA/AA/C/D and CR123 sized cells common to most stores (often a cold weather or long storage choice).
____I intend to use Rechargeable cells (NiMH or NiCD) based on the usual AAA/AA/C/D sized cells common to most stores.
__x__I intend to use Rechargeable cells based on less common formats (18500 or 18650 Li-Ion, RCR123, et-al).
____I want a light with an integrated rechargeable battery pack.
____I don't know/I need more information on power sources.
____I want a light that plugs directly into the wall (literally with prongs built into the light)
____I want a light that has a recharging adapter (your typical "wall wart")
____I want a light that snaps into a cradle (usually mounted on a wall)
____I want a separate/stand-alone charger (this involves removing the batteries to charge)
__x__I don't care
____I want to navigate a dark room or read a map (1-10 lumens).
____I want an indoor "blackout" light (15-50 lumens)
____I want to confidently walk around an unlit/unpaved rural area (60-150 lumens).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
___x_I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
____I want search and rescue type illumination (800+ lumens).
__x__SPECIAL NOTE: Burst/Turbo mode Category - There are several lights that will run at a super bright maximum for a very limited period (usually 5-10 minutes) and then will "step-down" to a lower level for thermal control. Check here if this is acceptable.
__x__Zoom
____All Flood: I am doing "arms length" tasks like reading and campsite cooking.
____Wide Flood: I want a defined flood area for semi-close tasks like after-dark campsite tasks or working on a car.
____Narrow Flood: I want a sharply defined flood area that will project some distance for tasks like trail walking.
____Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
____Narrow Throw: I want a beam with a very tight "hot center" and minimal "side-spill". Good for distance viewing, fog, and looking through dense undergrowth.
____Turbohead: I want a far-distance projector with a sharply focused spot of light and minimal or zero side-spill. Good for extreme distance and impressing your friends.
____Less than 1 yard/meter (reading, other close work)
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
____5-20 yards/meters (check out a noise in the backyard)
___x_30-50 yards/meters (I have a big backyard)
____150+ yards (I am searching from a helicopter)
____30-60 minutes (I have plenty of batteries just ready to be changed)
____90-120 minutes (Runtime is moderately important, but still not critical)
__x__3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
____Not Important (A "night-stand" light).
_x___Very Important (Camping, Backpacking, Car Glove-box).
____Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don't know.
__x__Any size switch will do.
____I need a BIG switch (I'll be using gloves or have very large hands or coordination issues).
____I want a forward clicky (Helpful for momentary activation and signaling).
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
____I want a body mounted switch (near the head, like on a Maglite).
____I want a tail mounted switch (found on the majority of today's high end lights).
____I want a remote switch (usually found on high-end bicycle headlights)
____I don't care.
____I don't know.
____A simple on-off with only one output level is fine for me.
__x__I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a selector ring.
____I want a strobe mode. (Oscillating pattern to confuse/blind aka "Police Mode")
____I want SOS mode. (blinks in ...---... emergency pattern)
____I want a beacon mode. (Regular flashes at full power to show location.)
____I don't care.
____I don't know.
14)Material/Finish/Coating
__x__Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's higher end flashlights).
____Stainless steel (durable, but much heavier than aluminum)
____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
____I don't care.
____I don't know.
15) Water resistance
____None needed
__x__IPX4 (Splash resistant)
____IPX7 (Waterproof to 1 meter/30min)
____IPX8 (Submersible to greater than 1 meter for 4 hours)
16) Storage conditions
____In house (temperature/climate controlled environment)
____Emergency kit (long standby periods)
____Automobile glove-box (wide temperature swings, long standby periods, critical reliability)
__x__Other_______EDC__________________________________ ____
____"Hybrid" light (bright incandescent combined with long running LEDs)
_x___Pocket/belt clip
____Holster
____Wrist/Neck Lanyard
____Crenulated bezel
____Non-sparking, Intrinsically Safe (IS) for use in explosive environments
daffy
AU
[h=1]Haikelite HT08vn - Best Compact Zoomie R[/h]$ 88.00
  • DriverVN4
  • Oslon 6500K 550 Lumen, 125Kcd Intensity
  • Surprisingly high flood output
  • Perfect artifacts free beam at any zoon ramge
  • Stiff but quality zoomie holds focus
  • Excellent build quality and optics
  • Ultra compact size
  • LED super close to optics for max wide mule like flood
  • Widest spill beam of any light
  • Love this thing!
  • Finally a zommie perfected!
Mine is for sale never use it
