Imalent
Results 1 to 14 of 14
Thread: major screw-up?
    Nov 2007
    Portland,OR
    Default major screw-up?
    I think I accidently put my brass Peak Eiger thru the washing machine.
    Am I screwed? (in terms of killing my light)????
    HELP!!!!!
    Flashaholic* jamesmtl514's Avatar
    Oct 2009
    Montreal, Canada
    Default Re: major screw-up?
    Is there water in it?
    Did you open it up to look?
    Like all electronics, take it apart, put it in a zip lock bag with dry uncooked rice for ~24 hours and try firing it up.
    Most modern flashlights should be able to withstand a laundry cycle.
    Good luck
    Sent from my Pixel 4 using Tapatalk
    My lightsWTB: Surefire: New/Used/Rare. Currently looking for everything Crosshairs + D2. Interesting trades available.Everybody, just send your lights directly to James - he'll end up with them anyhow, lol. -Kestrel
    Nov 2007
    Portland,OR
    haven't checked yet.I'll see when I get my clothes out of the washing machine.
    It was in the pocket of my shorts.
    The head was screwed on tight.
    I use silica beads as a desiccant to remove moisture.. But rice is readily available.
    Sent from my SM-N976U using Tapatalk
    Flashaholic Katherine Alicia's Avatar
    May 2020
    Central UK.
    Don`t switch it on!!!! just take the battery out, check for signs of water ingress and if there is any, soak it in pure 99%+ IPA and make sure it`s well flooded then let it dry naturaly.
    *Flashaholic* thermal guy's Avatar
    Jan 2007
    ny
    Very unlikely anything is wrong with it. It’s a peak. Fully potted. She’ll be fine.
    If i had one day left to live i would want to be at my workplace.Because every day is like a frickin eternity.
    Aug 2015
    Virginia
    If my olight s1 can survive multiple washing’s I’m sure that peak eiger is enjoying it like a fat bearded dude in a hot tub. (Me)
    Big butnotsomuch-burly
    Moderator
    archimedes's Avatar
    Nov 2010
    CONUS, top left
    That's no good for the battery.
    The Peak should be fine.
    ... is the archimedes peak
    Yeah, fully potted. Should be just fine.
    Definitely toss out the battery though.
    Jan 2007
    ny
    If the light did what it was designed for that battery should be dry and fine😁
    Oct 2009
    Montreal, Canada
    Update?
    Aug 2015
    Virginia
    Battery won’t have a drop of water on it near it or around it if it was screwed together right.
    Flashaholic Bazar's Avatar
    Dec 2016
    Colorado
    Don't turn it on till you dry it out. Water might be in there and let it work, but electric damage can happen if you run it with the water in there
    My Favorite owned: Acebeam T21VN Oslon, Acebeam X80GT, Emisar D4TI 18350 hi LED, Fenix TK75 '15, Fenix FD20. Other: Fenix tk09, Emisar D4 hcri LED, Fenix BC30, Fenix tk32 '15, Coast polysteel full line, Coast g10.
    Apr 2008
    Cleveland,Oh
    I would check for water ingress into the optic. Barring that, dry it off and keep using it.
    Great spirits have always encountered violent opposition from mediocre minds.
    -- Albert Einstein
