Imalent
Results 1 to 4 of 4
Thread: Arc-LS regulation?
    Dec 2003
    Maryland
    Default Arc-LS regulation?
    This propably has been addressed before but, does the LS provide a signal of some sort when it goes out of regulation? I've had the current battery in mine for what I would guess is about 2 hours or so. Just curious, thanks. [img]/ubbthreads/images/graemlins/bowdown.gif[/img]
    Flashaholic Geode's Avatar
    Sep 2003
    Nevada
    Default Re: Arc-LS regulation?
    Someone will give you a better answer than mine. The LS drops down into the "moon mode", which is significantly less bright. I do not know if there is another signal, per se.
    *Flashaholic* Flying Turtle's Avatar
    Jan 2003
    Apex, NC
    I think I noticed my LSL flicker a bit at about the time it went into moon mode. I thought then it was a bad connection, but I seem to remember reading here that this is normal.
    this_is_nascar's Avatar
    Mar 2002
    Gloucester, New Jersey
    Archvile, it will start to flicker/blink. This will occur somewhere around 2 hours and 10 minutes with a brand new cell constantly running.
