NITECORE -- Keep Innovating
Results 1 to 11 of 11
Thread: UCLs available now
    Flashaholic* Likebright's Avatar
    Jul 2003
    Arkansas
    Default UCLs available now
    The 22.8mm UCL lens that replaces the stock lens in the Arc4 are now available at www.flashlightlens.com for $7.00 each.
    I have just installed mine in the light and like it. It is so clear you don't even see its there.
    Mike [img]/ubbthreads/images/graemlins/grin.gif[/img]
    this_is_nascar's Avatar
    Mar 2002
    Gloucester, New Jersey
    Default Re: UCLs available now
    How difficult what it to remove the retaining ring?
    Is there a difference as to which side of the UCL goes towards or away from the LED?
    Did it fit without any modification or addition of o-rings, etc?
    Question: Is there any difference in brightness when installing the new Lens over the stock one?
    Brian
    Jan 2004
    Germany, Karlsruhe
    Do you also have lenses which fit into an ARC LSH ?
    Mar 2002
    My biggest fear in using this UCL lens is it's durability when compared to the stock lens. How well will it survive a bump or fall?
    Jan 2004
    Warren, MI
    [ QUOTE ]
    [/ QUOTE ]
    I got my UCL yesterday and haven't installed it yet but some have stated that the threaded ring comes off easy. I got a watch wrench from Harbor Freight weeks ago and tried to remove the ring on my Arc 4+ then and was it so tight that I burred the slots a bit! You'd have to look close to see the damage. The small pins don't fit perfectly and I may make a set that fit perfectly.
    I might see if I can get a replacement ring from Arc.
    Jul 2003
    Arkansas
    Nascar,
    I used the watch wrench from Harbor Freight too. You have to be very careful that the pins fit snug into the retaining ring. I filed mine a bit to get a tighter fit.
    I think the things are equally coated on both sides so its any side out.
    I just dropped mine in inplace of the original lens. There was some talk of a gaskit to protect the glass lens from the retaining ring. I didn't see a need for one.
    BMStroung
    There certainly seems to be a perceived difference. It seems brighter.
    Unfortunately I didn't measure my light output before replacing the original lens.
    SpaceMarine
    I think Chris is trying to get some but doesn’t have them yet. The LS is a different matter when it comes to replacing the lens as it has to be opened.
    Nov 2003
    FLA
    The original lens is pretty thick (.090 I think). Is this new lens similiar thickness to the original? Previous discusion mentioned that some of these replacements were much thinner and would need a shim.
    Jim
    Jul 2003
    Arkansas
    Jim,
    It is almost the exact same thickness.
    Mike
    Nov 2003
    FLA
    Thanks Mike,
    Has anybody tried the UCL-LDF with the the Lexan dispersion film? Comments? Would the lexan film side go in or out?
    I am thinking about gettin both kinds. The isolated lens (out of stock) also sounds interesting since it should greatly reduce the chance of breakage.
    Jim
    Jan 2004
    Warren, MI
    [ QUOTE ]
    Brian
    [/ QUOTE ]
    It was posted by the dealer to be 12% increase over a stock lens.
