Imalent
Results 1 to 10 of 10
Thread: WITHDRAWN Electro Lumens ST90 update
    Nov 2004
    Adelaide, Australia
    Default WITHDRAWN Electro Lumens ST90 update
    Electro Lumens ST90 Search and Rescue.
    Around 2200 lumens, has 3.5"/90mm reflector.
    In original condition, used for beam comparisons, will suit a serious collector, had a neutral white LED installed at the factory, very long throw.
    Will send with Nitecore i4 charger but no batteries due to postal complications.
    Attached Images Attached Images
    Oct 2013
    Russia
    Default Re: Electro Lumens ST90
    Does it have two independent drivers?
    Nov 2004
    Adelaide, Australia
    Hello ma tumba, I have no idea, it does have two switches for low and high, other than that, don't know.
    Oct 2013
    Russia
    what happens if both switches are activated simultaneously?
    Nov 2004
    Adelaide, Australia
    Quote Originally Posted by ma tumba View Post
    just tried it......first switch turns it on and the other controls the high/low level....then the first switch turns it of.
    To turn on both switches, you would need to use two fingers at the same time, I did not do that...
    Oct 2013
    Russia
    this makes sense, thank you!
    Flashaholic* chipwillis's Avatar
    Nov 2007
    Minnesota
    What would shipping cost to Minnesota
    Once things leave my hands I am not responsible for what happens.
    Nov 2004
    Adelaide, Australia
    To make this easier for all, and checking the actual packaging as well, I have adjusted the price to include postage anywhere that we can send to easily. (some countries are excluded)
    Nov 2004
    Adelaide, Australia
    bump?
    Nov 2004
    Adelaide, Australia
    After having a close look at the postage costs for this light to various areas, I have decided to cancel this sale.
