They told me that it is about 4.5A continuous. So, like Chris said no way. I did not post this to Troll. I was hoping it would work for a few minutes. Which is all I use it. I figure now that it might not be worth the risk. The h17 does not let you choose type of cell AFAIK. Even so 1.5A you could overdrive maybe 1.5x. Not to 4.5A. That is continuous. It might burst to 7A or more. That little 123 is almost guaranteed to blow. We all know that Lithium Primaries can blow catastrophically. Even if it is protected that is outright abuse. Which may defeat the protection.
As I mentioned, I kind of like my hand. Again, I honestly did not already have the answer to this. I was hoping your guy's answer was going to be no problem it will do it. That is really not the case. I just googled one XPL-HI easily exceeds 1.5A. Here we have 3 of them and they are overdriven. I think a full 18350 is over 4.25V. Most 123 are not even 3.7. 3.5 is nominal. Seriously though I was hoping I was going to get the green light. I am nowhere even close and I honestly did not know this. I guess there is a reason he told me 15 amp battery. I thought it was 5 amps continuous but I just checked it. It is 5.5 Amps.
It is actually not horrible for me because it is LSD. After 6 months it is at 85%. I really did wish I could use a primary the way I use it. I just have to remember to charge it. Another good thing, after 6 months at 2000ma it takes 10 minutes to top off. So really it is not that big a deal. Where I will run into trouble is if I forget to charge it. Thank you folks. I appreciate your help.
