Comparison of IMALENT MS06 and DM70
imalent
Shenzhen
IMALENT MS06 is a can-sized super bright searching flashlight that blasts a max output of 25,000 lumens and a max beam distance of 513 meters. This 25,000 lumens flashlight can be quickly charged with the three included 4000 mAh 21700 Li-ion power batteries via the magnetic USB port. The amount of light that the IMALENT MS06 flashlight emits is truly remarkable, a wide beam angle and strobe function are quite ideal for Searching and Rescue. Extremely small for a flashlight with this much power, only 4.68" long plus a flat light body, this flashlight is the perfect tool for exploring and search and rescue. The battery level indicator lets you know the status of your batteries. Additional features include intelligent memory circuit, lockout function and six output levels. Once you see the raw power of a 25,000-lumen flashlight, you will never feel troubled at night adventures, such as searching, caving, patrolling, etc.
the imalent MS06 with 25000 lumen power
https://www.imalentstore.com/products/imalent-ms06-25000-lumens-flashlight
The tactical flashlight IMALENT DM70 has excellent performance. This compact body is only 115 mm long with a maximum output of 4,500 lumens and a beam distance of 306 meters. It uses a micro USB rechargeable 21700 lithium-ion battery. which can be used for daily outdoor activities and maintenance work.
the imalent DM70 with 4500 lumen power
https://www.imalentstore.com/collec...ore/products/imalent-dm70-tactical-flashlight
