HDS Systems
Results 1 to 3 of 3
Thread: Klarus XT21X not working
    Nov 2012
    Manila, Philippines
    Default Klarus XT21X not working
    We left the light on overnight on level 2 it had a full battery but when I woke up 5 hours later the light was off so and wouldn't turn on. When I plugged it in the light was flashing yellow that means it needs an inspection according to the manual. Does anyone know how to fix this problem without sending it to the factory? I. t is only 6 months old. It doesn't make sense the battery is at 3.76v when I tested it. I have a pic and a video but don't know how to post them.
    Default Re: Klarus XT21X not working
    Considering the battery doesn't last 5 hours on the level you had it on, I'd say you overdrained the battery and your tester is faulty. Try a different battery in the light. If it works, it's the battery. If it doesn't, it's the light that failed. Did you use an unprotected battery in the light?
    Nov 2012
    Manila, Philippines
    It was the factory battery after cutting the klarus wrapper off I seen is was a Samsung INR21700-50E. I put the only battery I have in the light a 18650 LG hg2 and put a perfect size of aluminum foil take up the space and it works fine and even charges the battery. I know my tester is not faulty it is a professional grade fluke multi-meter I'm an electrician so I needed the best tester I could buy. Klarus said the battery is covered under the warranty and will send me a replacement.they said the protection circuit failed.
