Re: How good are laptop 18650 batteries for basic use?
They're fine. I have some 26F cells, and they work just fine in my Convoys. Max current draw in the Convoy is 2800mA (assuming you bought it with the max config), and that's well within the 5200mA max drain of those cells.
Even in lights with a FET driver (such as the BLF A6), they work fine. They don't give quite as high output as a 30Q, but they're still pretty good. With a FET driver, their inherent voltage sag will limit current to under 4 amps.
Originally Posted by
WalkIntoTheLight
I don't have a charger that analyzes battery.
I checked with multimeter and the volt is good.
Can I also check the resistance with a multimeter to make sure they are good?
Mystery
Internal impedance/resistance of batteries
Mystery
Not easily at all. To check resistance, just compare them in a light with a FET driver, against a good battery. Or, don't bother, because if the resistance is too high to use in your Convoy, you'll know it. (Poor output, and/or short run-times.)
adamlau
Thanks.
Looks like it won't work with my multimeter.
It only goes down to 200 ohms.
WalkIntoTheLight
I never timed it as I only use it around the house few minutes at a time.
Hopefully, after this stupid virus thing is over and weather warms up, I can go camping and use them for longer times.
you can use a brute force and not very scientific method if you did not do some prep work.
charge up all the batteries and put them in the intended use flashlight. Leave light on high and start clocking it until light goes out. Then throw away those that does not last long enough.
Because those laptop batteries are all flattop, some light may require you to put a dab of solder on the +.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
Bookmarks
