Sold/Expired SOLD*Malkoff, SOLD*HDS
CRKDMike
GTA, Ontario, Canada
**SOLD**First up is a Malkoff M61WLLLL. I can upload pics if you like, but it looks just as it did straight from the group buy. S/N is #13.
$65 shipped within North America. Overseas will cost more.
**SOLD**Next is a unique HDS Rotary, 1 of only 12 made. Nichia 219c, NC27, 2700k warm tinted goodness. Also equipped with the first limited run of GITD diffuser reflectors.
The light looks brand new. It was only used sparingly around the house. There are some speckles in the anodizing, and it came to me that way.
$420 shipped within North America. Overseas will cost more.
CRKDMike
Malkoff, HDS
Does the HDS also come with the standard reflector or just the diffused reflector?
I can include the standard smooth reflector, or the diffused one with the light. My asking price does not include both.
*forgot to mention that if you want to HDS with standard reflector, then the price would go down $75
bigburly912
Virginia
Malkoff, HDS
FAQs:
(1) What is a Malkoff M61N LLLL? What exactly am I purchasing?
This is the Malkoff Devices P60 style Drop-in LED Upgrade Conversion with solid brass heatsink construction. This is a LLLL- that's FOUR L's (low low low low). Output is roughly 24lm (26lm @ 9V). The LED is a will be a 4000K Luminous SST-20 95 CRI emitter.
From the Malkoff Web-site.
This design utilizes a custom orange peel reflector designed by Don McLeish. The reflector offers a very nice balance between throw and spill. It is an outstanding room lighter and short to medium spotter. It was designed specifically for use in Malkoff MD2, Elzetta ZFL-M60, and SureFire 6P, 9P, 6Z, Z2, Z3, C2, C3, M2, G3, and G2 flashlights. It may or may not fit other models. The input voltage is 3.4 - 9 volts. Below 3.4 volts it will drop out of regulation and run direct drive. This dropin is protected against reverse polarity.
This Malkoff Upgrade is designed for rugged service from the ground up. It is fully potted to stand up to rough service and recoil. This item is covered by Our Lifetime Warranty
His is the warmer version so output will vary slightly
Robe
Oklahoma
Re: Malkoff, HDS
I was on the first run of the 2700. It's such a beautiful tint. Should have kept mine! Glws
