HDS Systems
Results 1 to 11 of 11
Thread: Copper tape?
    Default Copper tape?
    Any suggestions for the best copper tape to use when installing a high output P60? There are a few options out there on AE and the like but Iíve heard some people worry that the adhesive used might result in more insulation than not. Iíve tried the aluminum foil route but itís a PITA every time the drop in gets removed...
    Flashaholic* Katherine Alicia's Avatar
    May 2020
    Central UK.
    Default Re: Copper tape?
    my really broad tape I got from a Guitar shop, it`s used for sheilding the inside cavity around the pickup heads, so maybe that would work? if you want the narrower tape then some garden centers may have it (seriously!) it`s used to put around the top of outdoor plant pots to keep slugs and snails away, so it`s fairly weatherproof as well. Both of these can be soldered to as well.
    hope that helps a little
    Administrator Kestrel's Avatar
    Oct 2007
    Willamette Valley, OR
    I hear you on the thin aluminum foil hassle.
    If you're looking for something robust, I have used a single layer of aluminum soda can when the gap is large enough.
    It can require stout hand pressure to insert the dropin into the host on occasion, so I'm getting decent physical contact for those situations at least.
    Most likely being 3000-series, the thermal conductivity is adequate at least.
    I've never been sure what to do about the inner polymer coating, honestly.
    Heavy copper foil would be good, but not easy to find - maybe copper shim stock ? Good luck finding tho;
    I did go the copper tape route on a few of my dropins, but over time the associated adhesive lightly stained the brass (Malkoff) dropin bodies.
    Edit, just as a FYI;
    https://www.odmetals.com/blog/the-be...ded-heat-sinks
    *Flashaholic* thermal guy's Avatar
    Jan 2007
    ny
    You can try brass shim stock. No adhesive and you can get it really thin. .002.
    If i had one day left to live i would want to be at my workplace.Because every day is like a frickin eternity.
    Oct 2007
    Not the OP, but despite having brass shim stock available locally (very locally at this moment lol),
    the thermal conductivity of brass just doesn't hold up compared to aluminum, let alone copper.
    Edit: How about 0.004" thick pure copper ? Sounds like that's ~6x thicker than household aluminum foil.
    $9 for a hobby roll - I think it could be worth a try.
    https://www.amazon.com/99-9-Copper-S...a-822257542547
    Jan 2007
    ny
    how about copper shim stock? They make that to😁
    Think I used the wrong to. Anyone??
    my wife has copper foil tape with adhesive backing she bought at a craft store like Michaels or Hobby Lobby or something. It's like duct tape thick but it soft copper. I just cut the amount I need and fold it in half sticky side to sticky side.
    I've used it to bridge gaps in old broken copper sliders that move forward and backward like a tongue depressor in really old flashlights from the 1920's. So long as bare copper touches what you want to conduct it works just fine.
    John 3:16
    KITROBASKIN's Avatar
    Mar 2013
    New Mexico, USA
    Copper Foil Sample Pack did it for me. Usually I can combine 2 different thicknesses to get the ideal fit.
    https://www.quickshipmetals.com/samp...nless-pak.html
    May 2007
    Wisconsin
    Quote Originally Posted by thermal guy View Post
    how about copper shim stock? They make that to
    Yep, you used the wrong to(o).
    What kind of self respecting nocturnal being cannot see in the dark, one way or another?
    Jan 2007
    ny
    Figured someone would call me out on that. 😁
    Garden section at Home Depot is where I got mine.
