HKJ
[size=+3]Keeppower 18650 3500mAh P1835U (White-blue) 2020[/size]
Official specifications:
A 3500mAh protected 18650 with build-in USB-charger.
A pack contains two batteries and a dual usb charge cable.
The two cells tracks nicely and can handle more than 7A before getting too hot or protection will kick in.
It looks like the USB charger reduces current probably due to temperature at the start of charging.
[size=+3]Conclusion[/size]
A good protected battery with good capacity, the USB charging can be useful on the go or if you only have a few 18650 batteries.
[size=+3]Notes and links[/size]
The batteries was supplied by Keeppower for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
- Minimum Capacity: 3350mAh
- Nominal Capacity: 3500mAh
- Nominal Voltage: 3.7V
- Discharge End Voltage: 2.5V
- Standard Charging Current: 1.0A
- Max. Continuous Discharging Current: 5A
- Built in micro-usb charge port
