Jetbeam
Results 1 to 14 of 14
Thread: Connection not private warning
    Default Connection not private warning
    Using chrome on an iPhone all of a sudden there was a "connection not private" warning.
    When I log out I can look around without issue. Log back in and get same warning. Updated chrome.
    Anybody else having this issue?
    Posting this from the CPF apple app.
    John 3:16
    Default Re: Connection not private warning
    Iím having the same issue on my Mac.
    edit: also get the warning in Safari. I guess the security certificate expired?
    *Flashaholic* idleprocess's Avatar
    Feb 2004
    dfw.tx.us
    Same. Quoting doesn't work properly.
    I apologize that this letter is so long; I did not have time to write a short letter
    It is working normal for me now.
    It did say something about a certificate expiring. On another note I was suddenly not getting anymore junkmail so I deleted outlook and reinstalled it. I doubt that had anything to do with anything on my end unless shutting off auto sync everything thing played a role.
    Anyway it works normal on my chrome using an iPhone 8 now. It was just weird the way I was able to post, then I clicked on a thread to make a post and "wham!" not private pops up.
    John 3:16
    *Flashaholic* PhotonWrangler's Avatar
    Oct 2003
    In a handbasket
    This happened to me also on a desktop. I set an exception in my browser and I'm in again, although it's stating thaT some portions of the site (images) are not secure. I suspect an ad server's certificate expired...?
    Flashaholic* rookiedaddy's Avatar
    Apr 2009
    A Place Called HOME
    it should be in a matter or minutes once the certificate is renewed and applied to the server, and the warning should go away.
    changing sigline ...
    Welp the "not private" is back
    (using the app to write this)
    Aaaaaaaand 8 minutes later I'm writing this on chrome.
    So PW/RD are saying an expired certificate for an ad could be causing this?
    John 3:16
    Apr 2009
    A Place Called HOME
    it's the site domain certificate that's expire (3rd May 2021), because the server is serving content via https channel and a valid SSL certificate is required for this. Since it's a domain validated certificate, once it's renewed and applied to the site, the warning should go away in the next request, entire process could be done in few minutes. However, if it's OV or EV certificate, then it could take from 1 to 3 days (EV can take up to 5 days) for it to get issued and updated.
    Flashaholic* Katherine Alicia's Avatar
    May 2020
    Central UK.
    had the same, "The certificate for www.candlepowerforums.com expired on 03/05/2021.
    Error code: SEC_ERROR_EXPIRED_CERTIFICATE"
    The Underground isn`t affected, and if you`re using Firefox you can make your way past it and get in anyway (as I have done to get here).
    Administrator Greta's Avatar
    Apr 2002
    Arizona
    Working on it.
    Apr 2002
    Arizona
    Should be ok now.
    Feb 2004
    dfw.tx.us
    Quote Originally Posted by Greta View Post
    Should be ok now.
    Appears to be Working As Advertisedô now.
    Oct 2003
    In a handbasket
    Working normally for me also. Thank you!
    Moderator Alaric Darconville's Avatar
    Sep 2001
    Stillwater, America
    Quote Originally Posted by rookiedaddy View Post
    Why did you blur out the certificate issuer? Anyone examining the certificate will get that information, it's not a secret or anything.
