Using "flash amps" to test the battery in my ARC 4+ (second) I came up with the
following data.
The light was used intermittently at about the same amount of use throughout the period.
This is not very scientific but may still be interesting.
10.5 NEW
9.8 at 13 days
9.1 at 19 days
7.5 at 23 days
6.9 at 26 days
5.1 at 30 days
At the 5.1 "flash amps" (and 2.68V unloaded) the ARC 4+ would not surge to full power.
At this point I replaced the battery
At the increasingly faster rate of discharge I figured that I had used most of
the energy in the battery.
Conclusion (just my guess):
The battery declines slowly at first and then declines at an ever increasing rate.
This is probably due to the regulated ARC 4+ pulling more from the battery as
it declines in order to keep the brightness constant.
An unregulated light would probably have "needed" the battery replaced at
about the 9.1 - 7.5 amp level (or sooner) due to decreasing brightness.
I definitely prefer the regulation. That is my main reason for buying the ARC 4+
That...............and the selection of power levels.
Again......this is not scientific but, may still be informative.
Glenn
following data.
10.5 NEW
9.8 at 13 days
9.1 at 19 days
7.5 at 23 days
6.9 at 26 days
5.1 at 30 days
Glenn
